motofiaccone
OK, Gents:
Whilst looking at the VB catalog for rear axle lowering kits, I decided they were priced too high. I can make my own much cheaper...
The struggle is finding long enough U-bolts. In my previous builds, I always used Grade8's for the highly stressed areas. I found a supplier that will make me some custom U-bolts in the size I need, but they will only be grade 5. Since the stock U-bolts are 3/8", should I go up to 7/16" or even 1/2"?
I underdtand that the retaining platform will need to be modified--or even re-fabricated--and I'm OK with that. I'm just curious your opinions.
Racers: What do you use?
--Thanks, Chris
--Thanks, Chris
