Paul Johnson
Putting new bushings in the steering column turned out to be easier than expected. However, there was difficulty in wiring up the column, and I'm supposed to be very good with wiring. The colors all matched, doubly checked against a cheat sheet when coming apart and against the shop wiring schematic. Admittedly there is some difficulty with brown/green, especially in old harnesses and older eyes, but still after about 15 double checks it should have worked.
Right turn signal would turn on the headlights, parking/tail lights were always on and the headlamp column switch was non-functional.
You know already what I couldn't see for being so close to it. I had the turn signal and headlamp switches each mounted in the other's place. /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
