Bought TR7 with blown head gasket. Last night got all bolts/studs out save one stud which snapped. Will escalate the war after posting this. The question though.. it appears the radiator tanks have been pumped up from the inside so to speak. (The radiator didn't leak when I started the car, even drove it a few hundred yards). If the radiator was damaged like that, is the 6 vane water pump likely to be damaged too? Also, can the 6 vane water pump be replaced by the 12 vane and if so should it be done since engine is coming apart anyhow? OH! Suggestions of anything else I should check or replace while it's apart would be appreciated. Thanks.
