TR6 TR6 wheel bearing dust cap replacements ??
ALLAN
Are there any replacement dust caps from some other application that will work, something that has a surface that you can actually grab onto with a pair of pliers, or at least a little better than the stock ones ???
jsneddon
Are TR6 dust caps somehow different from the TR3 caps (or caps on about 10 other cars I've worked on) ????
Just wondering because this always seems to be a point of frustration here on the forum and I've never had a problem.
I've got a very sharp flat screwdriver with about a 1/8" tip. Gently tapping it with a hammer into the "lip" between the cap and the hub and working my way around the edge will start working it out enough to get a bigger screwdriver in. Gently twisting the bigger screwdriver while working around the edges and it pops right off.
Kind of like opening a metal paint can.
Does the TR6 cap have the edge "inside" the hub instead of along the "outside" of the hub or something??
A
ALLAN
The TR6 and probably the 4 have caps with no edges (shoulder), you drive them in and they bottom out on the inside edge. It is pretty tough to wedge a screw driver between the crack (without bending the cap).I can get mine off but instead of screwdrivers, chisels, and hammers-it would be nice just to grab the cap with a pair of channel locks--the way most other none british cars are.
jsneddon
[ QUOTE ]
[/ QUOTE ]
Thanks. An inside edge explains it all.
And here I thought you guys were just a bunch of whiners /ubbthreads/images/graemlins/devilgrin.gif
I've heard of people tapping and brazing a screw on the end so you have some 'purchase' to get a grip on it and yank it out. Others have mentioned brazing a nut on the end so that you can thread a long screw through it and have a built in 'cap puller'. I haven't heard of an alternate source for them but I also have heard that the replacement caps are made of inferior/flimsy materials compared to the originals.
71tr
Has anyone sourced a replacement cap for the TR6 any where other than the big three suppliers? Seems like a suitable local replacement would be available.
PeterK
The caps I have have a small hole drilled in the center that you thread a long sheet metal screw into that bottoms out on the end of the stub axle and pushes the cap off. Trouble is when the hole becomes enlarged and the screw no longer has a purchase to push the cap off. Then a brazed nut will do the trick. Never had to pry one off on the edges.
I made the mistake of powder coating a new set of caps. The coating was thick enough that I could not get the caps to fit inside the hub. So I had to blast off the coating (not an easy task) to get then to fit.
T TR6 TR6 front wheel bearing ? Triumph 5
I TR6 Rear wheel bearing help TR6 Triumph 6
N TR6 TR6 Rear wheel bearing Part #'s for timken Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
I TR6 TR6 steering wheel refitting Triumph 2
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
B TR6 Tr6 Steering Wheel Triumph 3
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
M TR6 TR6 Steering wheel refinishing Triumph 3
M TR6 1975 TR6 wheel alternates Triumph 1
N TR6 How to check TR6 front wheel bearings Triumph 1
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
I TR6 TR6 wheel trim ring questions Triumph 1
I TR6 TR6 steering rack/wheel allignment help Triumph 2
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
R_Lyle TR6 TR6 wheel choices Triumph 10
M TR6 TR6 wheel opinions Triumph 7
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
I TR6 69 TR6 Rostyle wheel cover questions Triumph 0
I TR6 69 TR6 wheel source? Triumph 1
I TR6 69 TR6 - Another stupid wheel question Triumph 8
I TR6 TR6 wheel blasting/painting Triumph 6
T TR6 tr6 front wheel bearings Triumph 15
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
C TR6 wheel offset/backspace TR6 ? Triumph 5
G TR6 Can finally drive the TR6 with a steering wheel Triumph 7
R TR6 TR6 Steering wheel advice needed Triumph 6
jjbunn TR6 Shift knob to Steering Wheel, TR6 Triumph 27
Steve1970 TR6 TR6 - Rear Wheel Alignment? Triumph 8
B TR6 TR6 aftermarket steering wheel Triumph 9
B TR6 Where/How to straighten steering wheel [TR6] Triumph 8
mrv8q TR6 TR6 Wheel stud Triumph 2
Brosky TR6 4 Wheel Disc Brakes for TR6 - Available? Triumph 17
WidespreadPanic TR6 TR6 Steering Wheel Removal Success Latest w/pic Triumph 26
B TR6 TR6 Wheel Offset for Minilites Triumph 7
J TR6 4 wheel alingment on a tr6 Triumph 12
I TR6 TR6 wheel centers Triumph 10
tr6web TR6 TR6 Front wheel alignment Triumph 4
C TR6 Correct TR6 Wheel Paint Color Triumph 4
A TR6 TR6 Rear Wheel Cylinders Triumph 5
G TR6 Another round of tires - TR6 16" wheel Triumph 10
Cain TR6 TR6 Wheel Cap Renewal Triumph 3
A TR6 TR6 Alloy Wheel Supplier Triumph 7
Alan_Myers TR6 Momo or Nardi steering wheel on early TR6? Triumph 6
