erstearns said:
Was installing a rebuilt dizzy and using a compression gauge to determine #1 cylinder compression stroke to roughly set timing.
I was hand cranking with a wrench. What should the compression be approximately? I assume that it would be somewhat less than when cranking with the starter or when running?
Any guess?
<span style="color: #000099">Eric, I know not alot about such things but I think
there are better methods to set the initial timing after installing
a new dizzy. (Compression will vary from car to car. You want to look
for uniformity)
I am thinking you need to static time your car. This will give you an idea
and then I'm sure the Triumph Experts here will correct my blunders and
help you out.
I did this task once and as I remember :
I took my valve cover off so I could watch the No. 1 cylinder valves opening
and closing, as I turned the engine fan by hand. I also pulled the spark plug
from Cyl No. 1 so I could see inside and place a long, thin wood dowel.
When the No.1 piston was near the top I watched the valve open and then
looked at the fanbelt pully for a timing mark. I did this several times until
I got close to piston at top with timing markers near each other.
Now, with distributor cap off, disconnect the low tension (skinny) wire from
the dizzy to the coil. Allligator clip a wire with a small lightbulb to the
dizzy spade and connected at the other end of the wire to the positive (red) pole
of the battery. If you are near TDC for cyl No. 1, the small light should come on.
Loosen the dizzy locking bolt on the right side and slowly rotate the dizzy
counter-clockwise until the small light blinks OFF. You have now found where
cylinder No. is located inside your dizzy. Put a small mark on the dizzy body
and on the dizzy cap for future reference.
Tighten the dizzy bolt, install the cap and spark plugs wires. Hopefully the
engine will fire up and you can fine tune the timing.
I think this is how I did it. If not, the experienced guys will correct my blunders.
good luck,
tinster
</span>
