TR4/4A TR4A wood dash
JSB
I am putting a TR4A back into shape, with a limited budget, and would like to find out if there is a template of the dash to make new one. Save some $$ for other parts. The original has water damage on the left end and is unuseable for this purpose.
Gary Pope
You could use your old dash as the template, but I would recommend that you buy a good quality dash. The home made ones are rarely as nice as a factory made one.
If you shop around you should find one at a reasonable price.
MDCanaday
If you're really all expenses spaired, try to epoxy the damaged section, you have little to lose, and you will know quickly if its really toast. Then search out a sorce of nice veneer woods, the process is like wall papering so give it a try.
Good luck!!
MD(mad dog)
TR4ATim
Hi, I'm a newbie on the BCF and would like to say hello. "Hello" Also I am a little short on cash and I'm making a wooden dash for my TR4A. I was able to use the old one for a template and got a 2'x 4' sheet of oak plywood at Lowe's. If you need a template I could trace one out on some heavy paper for you. I know the guys might not approve of the home made ones, but the cash I saved can go towards other parts. If you take your time, enjoy workng with wood and want the pride of saying I did it myself, it's well worth the effort. By the way I can make three dashes out of the 2'x 4' ply and it only cost about ten dollars. If interested, I'll let you know the tools I used.
Steve
Platinum
Welcome to the forum Tim! I am sure that we would all be interested in learing how the dash came out for you, and certainly which tools were used. Also, it would be nice to learn what you would do differently the next time that you make one
Dale
Welcome to this fine forum Tim!
I too appreciate your wanting to "do it yourself" It's the best way to fully appreciate these cars and to help preserve them. The more people who maintain the requisite skills the better to avoid any of them becoming a "lost art". And working with wood is an art. Shoot, working with these cars is an art. Albeit a black art.
Jon12
I have been thinking about making a new wood dash for my spitfire so any tips you have would be much appreciated. Like you said, it is nice to able to say I made that fine looking wood dash and saving money is always nice.
J
JSB
I have the luxury of a very good carpenter to do the real work on the dash. I just need to get a template for the complete dash. I have received way more responses than I ever would have guessed.
TR4ATim
I'd be more than happy to make a template for you. Just a thought, have you tried to transfer the dash to paper, as much as you can, then cut the right side out, lay it over to the left side and trace in what you are missing? Kind of a mirror image thing.
The way I've done mine dash so far is to take the old dash, lay it on the new piece of wood, then drill through the old dash screw mounting holes, then use wood screws to hold it steady while I trace around it. I then left the two together while I cut the rough outside shape on a 8" band saw, this takes some creative movements since I'm using such a small band saw. Once the outside was cut, I removed the old dash and used a small bench top drill press with an adjustable hole saw to cut out all the round holes, the tach, speedo and small gauges. To cut out the ash tray, vent openings and glove box, I used a held held jig saw with a fine tooth blade and one that will cut a small radius. Be careful around the glove box opening so you can use that piece for the door. Then to the router table to cut the counter bores for the small gauges and bevel the outside edges of the dash. With the counter bores done, I changed router bits to bevel the outside edges, this being the final process to having a completely cut out dash, I picked it up about half way around to admire my handy work and creative genius, then when I put it back down to finish the outside routing, I didn't notice that some of the bevelled angles are the opposite way. CRAP!!!! Well I did say I could get three dashes out of that one pice of wood. So now I'm on TR4A dash take two. Sorry to get so long winded or is it long fingered???
Thanks for welcoming me to the group, hope I can be helpful, if not, maybe entertaining.
Cain
I'm resurrecting this old thread to see if anyone has any updates or other ideas to refinishing a wood dash. I pulled mine out of my '71 TR6 last night and the old veneer is trashed and must be replaced. However, I'm not against making an entirely new hardwood plywood dash myself using the old as a pattern. Or I may just replace the veneer on the existing dash.
I guess I'm requesting any thoughts, ideas, or advice from those who have replaced/refinished their wood dash in the past.
Thanks
Eric
I re-veneered the dash on my GT6. The right hand end had been wet sometime in the past, and was stained and delaminated. I sanded it down to bare wood, got as much wood glue as possible into the delaminated bits, then clamped it to restore the structural integrity of the piece (plywood BTW, I think some earlier ones may have been solid. Don't know for sure)
Once that was done, I bought some veneer and glued it over the dash parts. (Used contact cement IIRC) I then brushed on thinned polyurethane (to penetrate the veneer) followed by a spray coat of urethane. Then I carefully cut the veneer out of the holes using a razor knife. Several repetitions of fine sanding and spray urethane and voila!
The only hard part was cutting the holes. I'm not convinced that the razor knife (Xacto type knife) was the best way to do it. After the rough cut, I sanded the edges smooth, but the result wasn't perfect. (I'm probably the only one who notices) You have to be careful not to splinter the veneer as you cut it. There may be some Dremel attachment to do this better.
BTW, I'm no furniture maker. My carpentry is limited to framing - finishing work drives me nuts. This was pretty straightforward to do - not hard at all.
CraigFL
Years ago I made a rosewood dash for my Europa using the regular dash as a template. Just do some studying as to what finish you want and how to do a super job. I had mine planed by someone with a power planer after I spliced a piece on for the console using a biscuit joiner. I then cut all the holes with hole saws on my drill press.
jeff3113
WOW - dash time!
I did the veneer thing. As a woodworker I could go about the full project or do the re-veneering. Re-veneering was going to be my first choice. I am very satisfied with the results. Once all the veneer is in place I found a dremel tool with the small sanding drum attachment worked great. Easily "sand" away all the excess. No chipping, splitting, or ragged edges. I used a combination of walnut and rosewood across the surface. I think one could get really fancy with veneering. In that, certainly don't underestimate that work involved or the admiration of a good job.
The look of a thick gloss coating also enhances the look. The local woodworkers shop wanted too much for the walnut burl or full rosewood veneer to suit my taste(of being thrify). Maybe next time. 24x96 inches would be more than I need.
That could do several dashes.
Good luck on the project and keep in mind being methodical is a good thing.
Regards,
Jeff
Geo Hahn
I've got the greatest respect for those with the skill & wherewithal to refinish or even scratch build a wood dash. For the rest of us, I'm thankful for sources such as TRF.
When I renewed the TR4 interior I planned to try to save the old wood but after pairing a 10% deal and the Winter Sale price the TRF dash was only $125.
Okay, not exactly lunch money but what a beautiful piece of work this is. Few things that just bolt on can make such a big difference in appearance.
Pic at: https://www.geocities.com/tucson_british_car_register/5dash.JPG
Winston
Just a quick response to Dale's post, I'd only add,if your not under your own bonnet you're not havin as much fun as you could be havin!
Welcome to the new guy's, hope you're havin fun with you're LBC.
Winston 67TR4A IR$
J
JSB
After reading all the responce's and talking to my carpenter, I am inclined to just buy a new dash.
jeff3113
FYI - There is someone selling solid dash panels on Ebay right now. Search for Triumph Tr6 and you should find it.
In regards to my veneering I found a local hardwood supplier that had some smaller pieces that were available. I bought a packet of walnut veneer for a couple bucks and added leftover rosewood as I wanted it. Found them in the local business phone directory. Woodworkers Supply sells the larger sheets. If I was to spend more than $60, I'd probably make the solid wood version.
Good discussions!
Jeff3113
V
vagt6
One possible source is at this link: https://www.speed6.biz/
It's the only one I've seen with a 3-gauge setup for the center, GT6 dash panel. Nice configuration. The walnut he uses is a bit darker than the original, French walnut on my '70 GT6, but it looks nice in the photo.
An friend of mine who is a very good cabinet maker says that the $220 price isn't bad for such a product.
I know nothing about this supplier, BTW.
Hope it's helpful.
Cain
How thick was the veneer you used? I'd like to get something I can sand on. The only stuff I've seen in the big box stores is paper thin. (I even asked one guy in the cabinet department and he was like "What's veneer?")
rulle7
If you're going for veneer, Tiger Maple
makes for a fantastic dash!
Made one for my Mini, veneer on plywood.
For an idea of what it might look like,
just check out your nearest violin.
My two yen worth.
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
Stinger TR4/4A TR4A Wood Dash Refinishing Triumph 18
K TR4/4A TR4A Dash...was the wood veneer stained? Triumph 12
Popeye TR4/4A TR4A Dashboard wood veneer - source? Triumph 14
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
