When I first tried the wipers on BB, they moved a few inches and stopped. Since it's been too hot to do any extended work here, I decided to remove and clean. Now that that's done as far as the gearbox, I was curious if white lithium would be ok to re-lube with? Most of the original grease in contact with moving parts was more like a paste with a lot of grit, so should i try to seal it up a little?
Thanks
JD
Thanks
JD
