TR4/4A TR4A commission number
Found a TR4A with strange commission number. Its 1CTC 59908 L0, I actually remember seeing one like that years ago. What does the 1 before the CTC mean. Car is a solid axle, late model 4A from what I can tell. Aren't those a low production number car.
Marv
3798j
Bronze
I think solid axle 4A's had only the letters "CT", while those with IRS were "CTC".
Lou Metelko
The TR4A began in January of 1965 with the numerical 50001 and ended with 78684 in July of 1967. As earlier stated the Independent Rear Suspension (IRS) had a prefix CTC with the solid axle a CT. I would guess the 59908 sequence number would be about an October 1965 production. That guess is based on my 4A IRS (CTC64139L) has a BMIHT birth date of December 30, 1965. Interesting to note that Triumph built over half of the total 4A production in 1965 which is further proof that by 1967 the ole tractor engine was at its end.
Lou Metelko
Auburn, Indiana
Cabrioman
Where is the commission number located please?
sail
Commission # on 4 & 4A is on the left firewall shelf by the wiper motor. Body number is on opposite side.
HerronScott
Cabrioman,
You are back to getting the hood/bonnet open!
Scott
Marvin Gruber
This car has the later IRS type frame but with solid axle and leaf springs. Also has the double lead exhaust manifold. Engine number is CT 78XXX E, looks to be the big valve high port head engine.
Interesting the 1 means a Belgium assembled car. Guess I should buy it.
Marv
HerronScott
Marvin,
Really interesting on the commission number being CTC but with a solid axle. Is the commission plate the original?
Regarding the double lead exhaust manifold, as far as I know all TR4A's had those.
Scott
Marvin Gruber
Scott,
Your question about the commission number being correct, that could be the telltale to the car. I believe it has been changed. Pop pivets holding the plate do look different. I believe (from some other resource material) that the car is a late 67 car. According to VTR, SU HS6's were installed in 66 and the engine has a 78k number puts it as a late 67. I read somehwere else that the solid axle was done in a limited run for folks who didn't want the IRS. Car looks rough but has good floors and rockers. If I buy it, I could send engine number off and get a BHMT cert on it.
Marv
HerronScott
Marv,
Looking at the TR4A's registered in the TR Registry, there were solid axles throughout the life of the TR4A. The last TR4A registered is a solid axle (CT78657L) in fact. I think I've seen some references that use 25% as a rough number that were produced with solid axles versus IRS and it was for the US market to please distributors here which felt they could sell them better with a cheaper price.
Both of my TR4A's have SU carbs and it sounds like the one has had a later engine installed since the engine and body number should be close to the commission number. My 1967 TR4A is original and has the following:
Commmission number: CTC 72159LO
Body number: 71922CT
Engine number: 72497E
It's possible you have a car that was put together from 2 separate cars - 1 IRS and 1 solid axle and they titled it under the IRS commission number but used the solid axle frame/suspension/body.
Good rocker panels and floors always sound good though! What's the rest of the car like?
Scott
Marvin Gruber
Scott,
This is an Alabama car, no paperwork other than bill of sale required. I am headed out to look the car over again. Will report findings.
Just to clarify in my head, any solid axle TR4a will will only have CT (instead of CTC)for the commission number? I do remember reading that the extra "C" meant that the car was IRS but also had it in my head that all TR4As were CTC.
Marv
Andrew Mace
"...any solid axle TR4a will will only have CT (instead of CTC) for the commission number? <span style="color: #FF0000"><span style="font-weight: bold">Yes!</span></span> I do remember reading that the extra "C" meant that the car was IRS <span style="color: #FF0000"><span style="font-weight: bold">Yes!</span></span> but also had it in my head that all TR4As were CTC <span style="color: #FF0000"><span style="font-weight: bold">No!</span></span>."
sail
From Triumph TR by Piggott.
HerronScott
Andrew Mace said:
CinneaghTR said:
I'll add to clarify that the frames are the same for either IRS or solid axle car. The suspension and diff/axle bits are different.
Doesn't the "live axle" frame lack the bridge piece for the diff. mount, etc.?
I've never seen a solid axle TR4A frame but that was my understanding as well. You would certainly need the mounting posts for the IRS differential out of the way.
Scott
Stinger TR4/4A TR4A Commission Number Question Triumph 8
R TR4/4A 1965-1966 TR4A commission number? what year is it? Triumph 8
T TR4/4A Tr4a commission codes Triumph 16
HerronScott TR4/4A TR4A original commission plates? Triumph 9
R TR4/4A TR4A COMMISSION NUMBERS Triumph 3
A TR4/4A TR4A commission tag paint and trim codes Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
