TR2/3/3A tr3 timing gears
sp53
Hello tr3 people has anyone purchased new timing gears from any of the big 3 recently. I used my old ones because I had heard about the reproductions having the holes drilled wrong and as a result causing timing problems. The gears I am using have become kinda pointed on the ends, but what the heck. I guess what I am asking is how many people out there are using their old timing gears without any problems.
sp53
Don Elliott
My sprockets for the timing chain are 48 years old and no problems. But I've changed the timing chain tensioner about every 15,000 - 20,000 miles or so.
Don Elliott, Original Owner, 1958 TR3A
S
sp53
Thanks Don I was hoping you would say something like that. How about the chain did you replace that with the tensioner.
sp53
Don Elliott
I changed the timing chain at 80,350 miles because it was all apart when I was doing a 3-year restoration from 1987 to 1990. It was fine, but I changed it anyway. This one is still fine after another 87,000 miles in 16 summers with no problems.
trfourtune
kent cams makes a replacement set with adjustable cam sprocket. i would go with this since it is adjustable and a matched set. you could get the adjustable sprocket from bpnorthwest wich looks like a cambridge motorsport sprocket. your chain will wear out faster with worn sprockets. i would not re-use the sprockets with a new chain. if you want accuracy in timing the cam, go adjustable. with worn sprockets, the timing is not accurate, the slop from worn sprockets lets the chain move back and forth, deceleration also will give different timing. remember that when installing the cam sprocket that is can be flipped to help index it.
rob
TRclassic3 TR2/3/3A TR3 Timing gears Triumph 5
BillyB62 TR2/3/3A TR3 timing/distributor question Triumph 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
G TR2/3/3A Advanced Timing Light for TR3? Triumph 6
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
M TR2/3/3A Timing the TR3 Triumph 5
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
K TR2/3/3A The goop on the TR3 timing cover Again? Triumph 3
mrv8q TR2/3/3A TR3 Static timing; point of confusion. Triumph 16
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
tinman58 TR2/3/3A TR3 timing? Triumph 5
RedTR3 TR2/3/3A TR3 Timing Question Triumph 3
PeterK TR4/4A TR3-4A timing cover tensioner Triumph 9
W TR2/3/3A Pertronix and timing in TR3 Triumph 20
H TR2/3/3A TR3 Timing Chain Triumph 13
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
Tinkerman TR2/3/3A 60 TR3 Cam Timing Triumph 4
TRclassic3 TR2/3/3A TR3 timing and pertronix Triumph 8
M TR2/3/3A Cam timing TR3 Triumph 4
RedTR3 TR2/3/3A TR3 Timing Triumph 15
Tinkerman TR2/3/3A TR3-A Timing Cover Sear Removal Triumph 3
jsneddon TR2/3/3A TR3 Timing Chain Triumph 14
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
jscott TR2/3/3A TR3 timing Triumph 2
