Tires for 78 Midget w/Rostyles?
RickB
I have 155 80R 13's now, but would like something wider and better for road use - a more comfortable driving tire would be nice. I am pretty sure 165 70R 13's will work - anything wider without scraping the wheel wells??
I'm pretty sure I have 165's. I'll check when I get home, they work, but just barely. Turning with the wheel locked left or right causes rubbing. Also going over a bump or dip too fast is trouble.
I am having some trouble locating 165 70 13's at my local tire places.
I tried Discount Tire, Les Schwab and Sears.
What about 165x80x13's?
I checked, and I do have 165 r13's on my '79. I got them a little over a year ago. In the 13" rim size you're stuck with an 80 aspect height.
Also, take not of the dot date on whatever tire you buy. From what I understand, there's not much of a demand for 13" tires anymore. Much of the stock out there has been sitting on a shelf for a couple of years. Basically, you can get stuck with a tire that has half of it's life eaten up before you even buy it.
There's a couple places here with 165x80x13's.
I'll check them out. Gotta be better than the 155's I'm running now.
How do I check date codes?
Thanks Ed, you run 185/70R-13's on your Midget?
How does that work?
U.S. DOT Tire Identification Number
This begins with the letters "DOT" and indicates that the tire meets all federal standards. The next two numbers or letters are the plant code where it was manufactured, and the last four numbers represent the week and year the tire was built. For example, the numbers 3197 means the 31st week of 1997. The other numbers are marketing codes used at the manufacturer's discretion. This information is used to contact consumers if a tire defect requires a recall.
regarding tire age:
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=138
Thanks Tweety!
I see some 175x70x13 Fisk tires there - but I wonder if they will be too wide for my wheels & wells.
What are the thoughts about 185x70x13's?
There are several available in this size, but I don't know how well they would work in my SWA Midget.
https://www.miata.net/garage/tirecalc.html
This little program allows you to compare the size of one tire against another. What's really cool is that you can view the difference from side or the end so you can tell the width as well.
All I can tell you is that there is only about a half an inch between my side wall and the fender in my swa '79 midget. Again, I'm running 165 8 13's
I like the comparison charts, nice calc - thanks!
So if I could get 185 80R13's on there to replace my 155 80R13's I'd rev lower at the same speed by 8.3% - wow! Those would likely be way too tall though.
What about on hard turns? I suppose your car is at the factory set height still?
Mine is lowered, so tire rubbing is more of an issue.
Anyway, thanks one and all - I just got a set of 165x80x13's installed at the local Les Schwab place. It's nice to do business locally and they are close so I can take it in for rotating often and flat repairs are always free.
I will have to check it tomorrow!
Haven't checked pressure yet - I'm sure they are over inflated, that's SOP for Les Schwab.
It's officially top down all the time weather here in the NW. They say it should top 100F next week and the lows will be around 70F.
This morning I drove to work with the top down for the first time this year (intentionally - I'm not counting the time the top blew off the Sprite on the way in). :wink:
Well, now I'm curious...I've read lots of discussion on how <span style="font-style: italic">wide </span>a tire we can use. How <span style="font-style: italic">tall </span>can we go and still fit? My de-bumpered 1500 sits high enough that it looks like I could put a truck tire in there.
Lowering the revs by ~8% sounds mighty attractive to me. And tires are a lot cheaper than a 5-speed.
M Finding Tires for Midget??! Spridgets 8
B Midget Tires Spridgets 23
W New tires for the midget MG 0
W New tires for the midget Spridgets 6
G Street tires for the Midget Spridgets 17
nathandarby67 Which tires for a Midget? Spridgets 27
startech47 tires for a 79 MG Midget Spridgets 14
startech47 79 midget tires MG 4
J Largest Tires on R/B Midget Spridgets 1
B Wheels and Tires Selection Austin Healey 10
Lutz Kramer Tires Squeaking on Curves Austin Healey 4
Got_All_4 For Sale 2 Vredestein Sprint + S80 Tires 165 R 15 86S Triumph Classifieds 0
red57 Michelin XAS Tires Austin Healey 38
D Vredestein Tires Austin Healey 11
tinman58 TR2/3/3A New Tires Triumph 10
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
johnrip Wedge tr7 tires Triumph 1
vette North East Tires Austin Healey 16
F TR6 Wheels and tires Triumph 10
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
S TR2/3/3A Tires Triumph 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
69MGC MGC What size tires will fit nicely MG 2
danstr6 For Sale Redline tires for sale Triumph Classifieds 0
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
edkap2002 TR6 wider tires Triumph 9
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
Bayless What tires for '67 Sprite? Spridgets 5
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
5 Sumitomo 13 inch Tires Spridgets 19
madhouse Need Dunlop 165/R15 tires Austin Healey 8
P For Sale Five 6.50-13 Bias ply US Royal Safety 800 tires for sale Spridgets Classified 0
Joe Schlosser Wheels and tires Spridgets 15
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
I For Sale Minilite replicas with Michelin tires $400 Triumph Classifieds 16
P MGB MGB tires MG 11
B XK-120 tires Jaguar 7
aero3113 Vredstein Sprint Classic Tires Austin Healey 28
davidb TR6 TR6 tires Triumph 13
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
Jim_Gruber New Wheels and New Tires for Bugsy IV Spridgets 5
D T-Series T is for Tires MG 10
H 280i Tires TVR 7
E Tires for BT7 Austin Healey 22
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Basil Vredestine Tires Restoration & Tools 5
