I am learning way more than I ever intended on this 'Project'!!!
Here's the latest. The distributor is an Opus D45DE4. The ignition is a Piranha. The original electrics and electronics are disconnected in the distributor. The rotor is Piranha. The wiring harness from the 'points' (light) go to the Piranha module. The vacuum inlet on the distributor was capped.
I figure that since there is virtually no advance with increase in RPM... The centrifugal advance is stuck (either gummed up or rusty).
I pulled the distributor and (Of course) cannot get the rotor off! It is soaking in penetrating oil as I type. Once it's off I can remove the plate and free up the weights.
I have attached a mighty-vac to the vacuum advance inlet and A: it advanced the distributor... and B: it held vacuum for over 10 minutes.
Next step is to free the mechanical advance and re-install the distributor. I will hook up a vacuum line to the inlet. Is the line on the carb (Marked with the arrow) the line I need to tap into?
That line runs to the other SU then across the firewall to a canister. I can 'T' in right above the distributor.
Hopefully this is worth the effort... and my wife will appreciate the car even if she doesn't appreciate the work involved!
Anything worth doing is worth OVERDOING!!!
Thanks again fellow masochists!
Michael~
My Sculptures
[ 04-22-2004: Message edited by: Turn Two ]</p>
Michael~
My Sculptures
