Tech help on diffential swap
mightymidget
I have a 1959 Sprite with steel wheels that I am rebuilding. it has steel wheels and my wife wants wire wheels.
I purchased a early midget parts car with wire wheels for the switch over. When I removed the rear end I noticed it has the same 1/4 spring set up as the 1959 Sprite.
Do the complete rear ends interchange? They appear the same.
I understand that if you install the wire wheel axles in steel wheel housing that the axles are shorter. So I am sitting here looking at them 25' apart and they look like they would switch out ok. Then I would have the correct differential housing with wire wheel set up
Billm
The wires will fit into the plate housing but the opposite won't work (this is true for the semi-elliptic Spridgets and I think it is also true for the quarter-elliptics)
You could do the swap that you are asking about but will be stuck with a virtually worthless wire type housing.
I would think that it would be better to do the full swap.
Bill
M
mightymidget
the full swap is what I was wanting to do, to avoid problems.
Can I take the MG Midget complete rear end and install into the Bugeye? The midget is going to scrap pile so I do not need to worry about that car
fordtrucks4ever
If both are 1/4 elliptic spring, then the complete rearend assemblies wiil interchange. To do a rearend swap from a later model with full leafs, you will have to cut and weld the spring mounts on housing. IIRC there is 1/2 inch or less difference in length between both axle housings.
M
mightymidget
exact same spring set up. this good news, makes buying the parts car well worth the money spent for it now
begorj
did you try to fit your drive hubs for the wire wheels on your
disc wheel housing Im told disc wheel axels from a 1500 are a common change because there stronger and i know the center section and axel spindal nuts from a 72 midget will fit I have them on my 59 MK1 it will probley fit without changing the housing if you would like i can ckeck axel lenth i have
wire wheel axels for a 72 midget and disc wheel axle for a 59
mk1 ?
M
mightymidget
I have removed all the rear suspension on my car for rebuild so I am just going redo then put the complete MG rear end housing, axles, brakes, etc.. in one piece under the Bugeye.
S TR 4 and 6 racers--tech help needed Triumph 7
glemon Thanks Buckeye Triumphs Tech Help Triumph 2
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
A Spitfire BMCNE Tech Session - Photo Album - Triumph 0
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
paul9999 Old tech diesel - empty Other British Cars 3
N Supercharger tech question??? Spridgets 8
glemon Tech Tip, Wonky Switches Restoration & Tools 3
DNK General TR Tech Auto Co. UK Triumph 0
Rut Tech school bodywork Spridgets 8
Brosky New "Trafficator" now available from Classic Tech Triumph 16
PAUL161 The Shade Tree Tech by John Weimer [Thanks John] MG 0
N Tech question??? Spridgets 12
B Healey 3000 tech Q Austin Healey 12
JPSmit tech Latest - spridget 50th [and the day] Spridgets 13
Gundy Incredible tech session pics Spridgets 16
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
G A tech question Triumph 13
Superwrench tech info FORUM Navigation Questions 1
PAUL161 Tech Tips Via the Motorhead web site. Helpfull! MG 0
AngliaGT Don't You Just Love Hi-Tech? Other Cars 19
YankeeTR Bumper Replating Tech....A Must See Post !!! Triumph 2
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
jaybird The 'bird's Tech Tip #17 MG 42
MGA Steve MGA NAMGAR Tech Notes Available MG 1
C Newbie Tech Question- Weber Carb Spridgets 10
C Tech Question Spridgets 13
C Tech question MG 10
D Tech Manuals Spridgets 9
S Tech Manuals... MG 2
R tech question to those that might know. MG 3
G Buckeye Triumphs Tech Tips Triumph 19
W windshield wiper tech on 74 XJ6L Jaguar 1
Patton Burning up rotors - plus tech tip to get home!!! Austin Healey 16
G Tech Session at Tom's Place MG 4
J Lotus Elise can be had with a sequential shifter and the new turbo tech supercharger Lotus 6
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
