Healey 3000 tech Q
Bull
Guys,
I need to know the distance from wheel mounting surface (WMS) to VMS on a 3000!
Thanks in advance
Cheers/ Jonas
B
Bull
Ok I'll try and explain :smile:
I'd like to know the axle width, i.e. the distance from the disc (rotor) face to disc face (on one axle, either rear or front).
Some people refer to WMS when they are talking about the surface on the disc where you mount the wheel.
Thanks/ Jonas
TimK
Why do you need this info?
B
Bull
Ok, I have a Healey 3000 Replica which has been run with Volvo axles (55 inch wide axles). I've opted to rebuild the front end using Wilwood Mustang II spindles and Wilwood brake setups incl hubs. I'm building a new crossmember incl towers from scratch and I'll be fabricating upper and lower control arms as well. Since the car had wider axles I thought that it would be a good idea to try and replicate the original as much as possible (w r t measures at least).
Thanks/ Jonas
elrey
I've got wire wheels on my 3000 so do not know where you need the measurement. There must be a real 3000 in Sweden you can measure for your requirements. Your original question was a little vague. My car is dismantled for paint or I would measure the "front track width" for you. You are looking for rear and front "track width". On an early 3000 the front track is 2.3 inches narrower than the rear track. The later 3000 [63-67] 1237mm front 1250mm rear. This is information obtained from the internet. I searched "track width austin healey 3000".
TimK
The factory shop manual lists the 3000 front track as 48 3/4" and rear track as 50". I don't know how that relates to your requested measure, but it measures from wheel center to wheel center. You can adjust for wheel width to get your desired measure. I think Elrey has the front and rear dimensions wrong. The front track is narrower than the rear track at least on the 100-6 and early 3000. I don't know the BJ8 data.
elrey
Yeah Tim, I typed wider when I meant narrower :crazy: , I fixed it above. Your figures are for the MKlll. which has less difference between front and rear track width than the earlier 3000s. The 2.3" figure was from a 1959. There were a lot of different measurements on the net. Thanx.
B
Bull
Ok and thanks!
The reason for placing the Q here was the fact that I found several contradicting measures when Googling (which I do know how to do)... Problem with "track" is that it's measured with the wheels so backspacing, rim width interfeares.
I didnt know that it differed front and rear - thanks for that.
I thought that the Q should be easy to solve with so many projects underway...
Thanks again/ Jonas
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
D Healey 3000 BT7 rear panels Austin Healey 0
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
E 3000 Healey Door Checks Austin Healey 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 8
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
C Austin Healey 3000 in Modsports Austin Healey 4
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
M Wanted Healey 3000 Austin Healey Classifieds 4
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
BN6 Healey 3000 Camshaft Identification Austin Healey 4
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
S New Member 1967 Austin Healey 3000 Austin Healey 5
C For Sale 1965 Austin Healey 3000 MKIII Austin Healey Classifieds 2
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
BN6 Austin Healey 3000 Cylinder Heads Austin Healey 19
Alfred E. Neuman Late Healey 3000 Spotted 0
pbraun For Sale 1963 Austin-Healey 3000 BJ7 Austin Healey Classifieds 5
crya For Sale 1964 Austin Healey 3000 Austin Healey Classifieds 2
R Healey 3000 Distributor Cap Austin Healey 20
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
R Repair a First Motion Shaft for a Austin Healey 3000 Austin Healey 7
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
R General Tech No Triumpn - Healey 3000 Clutch not engaging Triumph 18
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
S A $50 Austin-Healey 3000???? Austin Healey 4
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
S Hemmings has a Healey 3000 on the cover [and a Corvette] Austin Healey 5
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
apbos Austin Healey 3000 Hardtop SFO NFI Austin Healey 18
