Spitfire starting a barnfind spitfire
sabot
hi all,
going to try and start the 67 spit i picked up.
guy i got it from says it last ran about 9 years ago.
i already know i have to switch the battery cable's around when i put in the new battery.
what other suggestions are out there?
thanks tom
tosoutherncars
https://www.theautoist.com/awakening_a_sleeping_b.htm
I'll say... the only thing I disagree on there would be changing the oil before starting it up. If there is swarf, sediment etc. in the engine, it has most certainly drifted down to the bottom of the pan and 'sludged up'. It will not be removed by draining cold oil that's been sitting for heaven knows how long. If you change it cold, then start it up, all that junk is still in your engine.
I'm a proponent of doing everything else, starting it up and letting it get completely up to temperature, and *then* shutting it off and immediately changing the oil and filter. I would suggest doing it again after a few hundred miles, and then assuming a regular maintenance cycle.
Opinions will vary... that's my two cents.
tdskip
Hi Tom - I've used that list as my reference point on every cars that I acquired. You can opt-out of some of the items if you deem them not necessary, but all fluids and consumables is a good way to go.
Keep is posted, and good luck!
S
sabot
oil is cheap, i'll most likely change the oil cold at first and then right away when hot.
worse case, the motor is messed up or seized, i'll have to drop a rebuilt motor in that i got thru work........
thanks for the info
tom
guzzul
I would agree with Duncan above about all the crud settling down into to the pan. And for that reason I would want to drain the oil and then pull the sump pan right off and clean it out before trying to start.
They're not that difficult to get off (heck, you're going to do it at least once anyway in the coming months), and it would give you a good look at exactly what is in the bottom of it. You'd be surprised at what you find (like thrust washers, for instance) in some.
Along the same lines, I'd stick a new oil filter on before startup. They're cheap, and who knows what's in the old one?
Norton47
Ditto Ross
Pull the pan and clean and check thrust washers. Of course you can get a good idea of the thrust washer condition from the outside. Push back on the crankshaft with a pry bar or shovel handle and then have someone else step on the clutch. Watch how much the crankshaft end moves or better yet feel it, or best put a dial indicator on it.
The pan drops easy.
foxtrapper
My goodness but how some of you make this complex. Going through the linked list of how to start up a barn find, you may as well rebuild it, your most of the way there already following those instructions.
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
T TR4/4A Weird starting issue with my TR-4 Triumph 15
