Craig:
Yes it can. You will need to transfer the BSP hose adaptor from the cannister housing to the spin off filter housing. Since this is a much simpler configuration, involving the oil filter adapter, a gasket, the fixing bolts and a Mann filter, the cost will be less. $30 plus USPS shipping for this arrangement.
You won't need the banjo bolt, copper washers and the metal pipe down to the adapter.
Just make sure you have a removable fitting at the cannister housing. If this is an aftermarket kit, it may be BSP or it may be JIC or AN. All will work.
Give me a call and we can discuss details.
Best Regards,
Mike
