Upright spin on oil filter
AUSMHLY
You never know what's out there.
I have a side mounted spin on oil filter.
I didn't know they made upright ones too.
Photo attached is on a 65 BJ8 currently on Ebay.
GregW
Platinum
Well, I guess that would defeat the purpose of a less messy oil change. It might take longer for the oil pressure to get up also. /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
BlueRidge2
Looks to me that would be a couple of problems.
Oil would leak all over when you remove the filter and would the filter empty every time you shut the engine off?
Maybe he has it mounted upside down???
bighly
I think it is a spin on adappter that has been put onto an incorrectly attached angle adapter. I tried that (except with the filter pointing down) so it would look somewhat stock, but alas it hits the frame.
Gravity is clearly working against you in the photo.
healeynut
That's the old adapter that Moss used to sell that attached to the tecalemit head. The adapter is a piece of crap and should be thrown away, it does not seal between the inlet and outlet ports, negating the whole point of the oil filter adapter to begin with. I think it was probably designed by a retar.... er... mentally challenged troll with a correspendence degree in engineering.
Dave Russell
Yoda - R.I.P
A filter that has a GOOD anti-drain back valve should not have this problem. Some filters are notorious for having leaky valves. Just one of those little things that helps give instant oil pressure when starting.
Keoke
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Dave, but that filter he has on there looks like "Jiffy Lube's" to me.---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Michael Oritt Rear upright casting--source needed Racing 4
Michael Oritt Casting number on upright Austin Healey 3
T TR2/3/3A What are two holes for on TR3A back shelf upright Triumph 11
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
eschneider Spitfire Spitfire torque specs - rear upright / trunnion ? Triumph 4
L Offset upright bushings Austin Healey 5
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
AUSMHLY Front Wheel Spin Drag Austin Healey 6
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filters Austin Healey 19
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
I Took the car for a spin today...! Austin Healey 4
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
MisterB How to spin engine sans wiring harness? Austin Healey 3
Marvin Gruber Took the E for a spin today Jaguar 1
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B TR6 spin on adapter fit problems Triumph 6
M How well should the water pump free spin? Spridgets 4
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
J Spin On Oil Filters Triumph 5
Z TVR Tuscan Spin Mid Ohio 2012 Racing 0
D Stock oil filter vs spin on filter Austin Healey 17
T Can you help idenitfy this spin-on filter Triumph 4
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
scoutll A Series Spin On Oil filters?? Spridgets 8
R TR4/4A spin on adapter Tr4a Moss LEAK...HELP Triumph 18
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
M Took my car out for a spin [video] Triumph 3
justin_mercier Wedge Took the wedge out for a little spin. Yay! Triumph 14
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
