Jim_Gruber
Getting ready to reassembly the rear end and was taking apart my other LR Wheel Bearing from the Hub. The inner seal had totally disintegrated with what appears to be a whole lot of wire mesh on the inside of the seal. In looking at the LR Axle with AM I see two grooves worn all of the way around the axle right by the threads and I assume right where the bearing seal would touch. So now I see why this hub was leaking and leaking badly. And Wheel Bearing kooks like it was missing at least one ball from the races, could have disintegrated and that's what I saw in the wheel seal.
So now the question arises. Going to a sealed 207FF Bearing as well as new axle seals and Gently Used EN17 axles along with 3.9 diff which is gently used as well. Am I going to be able to get a seal here by changing out components or is that a place where a Speedi Sleeve is needs. If so what size. Or do I put in all back together with Permatex Gear Oil Gasket Maker. Hylomar is no longer sold locally. Package Seay this is RTV Formulated to resist Friction Modifiers from Diff Oils. This stuff says apply a bead to one side and around all bolt holes. No gasket needed. 1/16 to 1/4" bead around bolt holes and one side of Pumpkin. Assemble immediately and finger tighten bolts, wait an hour and then torque to specs. Wait 24 hours before adding diff oil. So my Questions.
1) So I have paper diff gasket soaking in oil right now. Do I use gasket with this Gear Oil Gasket Maker Y/N
2) Speedi Sleeve - Needed Y/n and if yes what size and where do I get one?
3) or just put in the new sealed bearings knowing that I will be changing to rear discs in the new future.
4) 2077FF Wheel Bearings do not appear to be handed that look like that can be installed / turned either way.
One more thing the pumpkin can only be installed one way I think. Or Can it go either way and if so what is the correct way?
View attachment 48553View attachment 48552
