TR2/3/3A TR3 Tie Rod Sleeve
karls59tr
I posted an ad in the Classified if anyone has a good one to spare. Doing a wheel alignment and the tie rod has buggered up threads. Moss has them on order. Vic Brit does not ship to Canada. TRF does not appear to have them in their catalogue. Want to get the car on the road to enjoy the summer driving. :encouragement:
TR3driver
Great Pumpkin - R.I.P
TRF has them listed as available; suggest you try ordering.
Believe it or not, TRF does not publish a full-line catalog for TR2-4. They have literally thousands more parts than are listed in their various short form catalogs (aka "Glovebox Companion", "Web Specials", "Featured Model" etc.). So the secret is to look up the factory part number in the factory parts catalogue
https://drive.google.com/open?id=0B2H2NJt34OffMWQ4N2EzZGQtNjc0Ny00YmE2LWFiN2UtZWYzMjNjNGFiYzY4
Then look up that number in TRF's database
https://gar.zeni.net/trf/
If the 'status' field shows "CUR", then that P/N is available to order (should ship within 2 weeks, often the next business day). Just click the "Add to Cart" button.
Even TRF's own employees sometimes have trouble with this process; and sometimes (but not very often) the database is wrong. But it works almost every time.
Note that searching "by description" often fails, using the actual P/N works much better. In some cases, the original P/N will have been replaced by a different number (particularly if it was a part originally supplied by Lucas, Girling, Lockheed, etc.), but then status will show as "SUP" and the new part number will be in the description.
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
M TR2/3/3A TR3 tie rod ends Triumph 6
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
T TR2/3/3A TR3 tie rods - made of precious metal or what? Triumph 6
mountainman TR2/3/3A TR3 Tie Ends Triumph 4
1 TR3 Fender spats sold on EBay. Triumph 0
J TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 0
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Pool Dad 1960 TR3 engine serial number Triumph 14
T TR2/3/3A TR3 coolant hoses Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
J TR2/3/3A "TR3" painted on the engine block Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
J TR2/3/3A TR3 gas tank mystery Triumph 5
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
T TR2/3/3A tr3 front carpet replacement Triumph 5
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 5
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR2/3/3A TR3 Hard Top Triumph 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 13
M TR2/3/3A Defective master cylinders Tr3 Triumph 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
M master cylinder brake/clutch Tr3 Triumph Classifieds 6
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Tr3aguy TR2/3/3A Started a Car revival channel for the TR3 Triumph 12
J TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
D 1957 Triumph Tr3 Triumph Classifieds 2
P TR2/3/3A tr3 side curtains Triumph 4
banjojambo Triumph tr3 vertical link wobble Triumph 2
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
C TR2/3/3A TR3 close by Triumph 2
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
D TR2/3/3A TR3 Headlamp Rings Triumph 8
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
K For Sale Rare TR3 Folding Lug Wrench Triumph Classifieds 1
A TR2/3/3A TR3-A replacement top Triumph 7
