ronzet
MGA Affectionados,
My 1957 MGA is now on the road after a frame off and I am working out the bugs.
I neglected the boil-out of my radiator and had experienced overheating due to my negligence... This has been rectified..
However, It still runs on the hot side even with a 160degree thermostat installed. After much research I discovered that modern thermostats are not completely compatable with the 1500. It appears that the design of the head has a thermostat bypass that allows hot coolant to recycle into the engine elevating the temperature. The MGA GURU's site recommends a fix by using a blanking plate with a modern thermostate set inside.
Has anyone used this technique and what has been the results.
My option is this or purchasing an aftermarket original design from Moss or VB but, with some of the experience I have had with the 'made somewhere else' parts from these resellers I am a bit reluctant to shell out the $45 for a part that will last only a little while...
Thanks...
Thanks...
