My 1958 MGA 1500 is very difficult to start even in warm weather. I gring on it for about 5+ minutes even using starting fluid before it will start.
I replaced the fuel pump to no avail. I checked and I am getting sufficient gas to the carbs. I removed the float cover on the first carb (one nearest firewall) and the chamber was dry. I cleaned the chamber, set the float and cleaned the needle valve so it would move freely. Checked other float chamber and it was fine. Car still very hard to start
I have installed a Petronix electronic ignition with a sport coil. No help. Once the car starts and warms up, it will restart easily every time. What do I need to do? In your reply, please be basic as I am not very mechanical.
Thanks, Don /ubbthreads/images/graemlins/confused.gif <font color="red"> </font>
