Spare tire cover
philknight
The spare tire cover on my TR6 had gotten old, warped and ugly so last summer I drilled out the pop rivets that hold the metal angled pieces. sanded and painted the angles and have checked every lumber yard and hardware store in my area for a replacement for the pressboard, masonite, or whatever the material is called. I can't see paying over $100 for a replacement from one of the lbc suppliers for something I could make for a couple dollars if I could just find the material. Anybody know what it's called and where I can get some? Phil
TR4nut
Keep looking. There is a hardened masonite, about 1/8" thick I think that should work. I used it once for replacement door panels on my first Spit. It is normally a dark brown color, versus the untempered flimsy kind.
Randy
P
philknight
I've seen the 1/8" masonite but I'm looking for 1/4" preferably smooth on one side, dimpled on the other, so as to appear origional. The stuff must be out there somewhere. If I go for a replacement product I'd go with plastic.
Phil
G
I've seen it done in 1/4" marine-grade plywood. Bulletproof. But no dimples.
Geo Hahn
Couldn't you just make the 1/4" smooth/dimpled masonite by sandwiching together a pair of 1/8" sheets? Modern glue is stronger than masonite and if you glue larger pieces then cut to size I doubt the seam along the edge would be noticable.
P
philknight
I like the ideas comming in. The origional material appears to be softer and more pourous than the hardened masonite that the hardware stores stock. I'm not sure that it would take paint very well, or would adhere with all the bumps and scuffs that would be going on. The marine plywood on the other hand would take paint well, but be far from origional. Don't know why I'm stuck on the origionality issue with this. Overall my TR is far from origional. Body is painted black, SS heat shield and radiater cowl, gear reduction starter, Miata seats, etc. Was the origional material so inferior that nobody makes it anymore?
Phil
vettedog72
Paint the whole thing with a sealer coat. May need a couple of sealer coats. Then the paint should not be a problem and you would have reduced the effects of moisture.
ichthos
I am in the same situation as you. I want to fix the spare tire cover, but I am not willing to pay the $100 or more for a new one. Besides, I always like to repair the original if possible. I like to keep everything as original as possible, so finding the correct material was important to me. I always called the stuff press board or masonite. In either case, I took the piece with me to Home Depot and matched it up perfectly. They sell partial sheets with the dimples on one side and smooth on the other. I bought one 2'x4' sheet. It was pretty cheap (can't remember the exact price), but I can check on the price if you want. Obviously it will be cheaper if you find a piece locally, but as a last resort, if you can't find what you want, PM me and maybe I could pick a piece up for you. I can cut it to size to save on shipping before I send it, and I can check on the shipping.
Kevin
trboost
The original material is .025 (1/4") masonite, one side smooth. It should be available in any home center or lumber yard. Ask for a scrap or damaged sheet since you only need a small amount. Just drill out the old rivets , cut to size & reatatch the parts. I also used the soft half of a Velcro strip to replace the felt on the runners.
Good luck.
P
philknight
I'll check again at the local Home Depot, they didn't have 1/4" when I checked. I still have the origional for a template. Thanks all, Phil
DNK
Mitch- Do you mind if I steal your drawing?
Don
trboost
Not at all, that's how I got it /ubbthreads/images/graemlins/cool.gif
I have it on a MS image file. I can email it if you need it or fax it, what ever is easier.
I think you can capture it right off of the post & save it.
ichthos
It sounds like everyone has got this covered, but I just wanted to correct something I said earlier. After talking to an old woodworking friend of mine, he said the correct term used to be "tempered hardboard". The difference between the two is that the tempered hardboard (as opposed to the regular hardboard) will withstand moisture, although he said he would paint all sides in either case.
Kevin
CinneaghTR
I'll back up Frank. Dear Old Dad and I bought 1/4" masonite at Home Depot. He used my dog-eared original to cut out a new one.
What I did was sand and spray paint the top until it was very smooth (I can see my reflection!). For the bottom, I sanded less just to get a good surface for the paint to take, which left slightly-flattened dimples.
I am still sourcing some vinyl scraps for the snap attachment before I can put everything back together and install the finished product. We'll see how long it holds up after that.
TR4nut
I had spotted this drawing before on the team.net list. I think maybe Pete Chadwell was the guy who made it. Here's a link to the pdf if you need it:
TR6 tire cover drawing
Randy
F TR2/3/3A Spare tire cover Triumph 8
F TR2/3/3A Spare tire cover Triumph 3
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
I TR6 spare tire cover Triumph 5
mgbmedic TR2/3/3A TR3A Weatherstripping / Trunk - Spare Tire Cover Triumph 11
bcbennett Spare Tire Cover Triumph 1
luke44 TR2/3/3A TR3 Spare Tire Cover - Lock Triumph 5
R TR6 TR6 Spare Tire Cover Needed Triumph 9
B BN7 Spare Tire Cover Replacement Austin Healey 6
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
S TR2/3/3A tr3 spare tire fit Triumph 16
O TR2/3/3A Spare tire Triumph 4
F TR2/3/3A Spare Tire Size Triumph 11
D Vredstein 185X70 Spare Tire Fitment Austin Healey 5
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
Chuck9482912 Mini Spare Tire Austin Healey 9
S TR2/3/3A body work on the spare tire panel Triumph 7
V spare tire Spridgets 5
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
S TR2/3/3A trunk/spare tire Triumph 9
maxwedge5281 wanted: spare tire holddown and body attachments Austin Healey 9
I TR6 69 TR6 spare tire lid Triumph 4
Superwrench Spare tire rod Austin Healey 2
F Proper location of chrome loop for spare tire strap? Austin Healey 2
Kleykamp Hole pattern on spare tire lock covers??? Triumph 5
mgedit TR2/3/3A Spare Tire TR3 Triumph 11
B MGB 78 MGB Spare Tire trunk lockdown thingie MG 13
H TR4/4A Spare tire bracket 4A Triumph 4
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
M TR2/3/3A TR-3A - spare tire Triumph 4
A TR2/3/3A TR-3A Spare tire lid rubber Triumph 1
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
tmc Tire size for the spare Triumph 10
HEALEYJAG spare tire Healey 100 Austin Healey 7
K TR2/3/3A Up-date on TR3 spare tire Triumph 6
bcbennett TR6 TR6 Spare Tire Triumph 27
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
tahoe healey Spare tire on boot Austin Healey 16
G TR2/3/3A TR3 Spare Tire Compartment, post-60,000 Triumph 5
CinneaghTR TR4/4A Spare Tire Won't Fit in TR4A Trunk Triumph 8
bigbadbluetr6 TR6 TR6 Spare Tire Triumph 1
1 BE spare tire [tyre] is slipping Spridgets 17
