Sap removal
Nelson
I just washed my Sprite and found some sticky blobs on the paint that appear to be sap. What is a safe way to remove that stuff without messing up my paint?
Gerard
I think your best bet is Tar and Bug Remover. There is an industrial version you can get if you have an automotive paint supplier in your area. EPA regulations (at least in California) have made that product the degreaser used for paint prep. The brand I have is PCL.
Mickey Richaud
WD-40.
No, really - works great!
BlueMax
In the mountains of North Carolina you will find the finest Fraser fur Christmas tree farms. My wife and I used to drive up their every December to have a fresh tree cut. They had these amazing machines that you shoved the tree in and it would pop out all nicely bundled on the other side ready to transport. Over by the machine they had gallons of isopropyl alcohol I ask what it was used for. They said Fraser fur produce a lot of sap which would gum up the machine; the fellow that was operating the machine said isopropyl alcohol was the best to keep it clean. Plain old rubbing alcohol will dissolved all of your sap and leave no residue and will not harm your paint. Just saturate a clean soft towel and lay it on the sap spot for a few minuets and gently wipe it off.
JPSmit
Swmbo just tells me to leave. :whistle:
Platinum
Mineral spirits. Same as the alcohol for tar and bug removal.
jsfbond
I sell related products for a living....the best, safest method is an ice cube and your (clean) fingernail.
dklawson
+1 for Mineral Spirits. It's what I use and one of our cars is always under a pine tree.
If you go for alcohol instead, read the rubbing alcohol label first. Make sure what you buy is isopropyl and water, not ethyl and water.
A non-solvent approach (depending on the size of the drops) is to use detail clay.
Nelson
Nelson
I tried the mineral spirits today and the sap is now gone. Thanks guys.
Jer
Nelson - did you get your gas line issue fixed ? I remember that was causing you grief at Elkhart...
Nelson
Nelson
I thought I had but yesterday I found that both carbs are leaking where the fuel bowl attaches to the body of the carb. The day before yesterday I drove about ten miles and went through about a quarter of a tank. I tried Bill M's trick of using an extra washer to squeeze the bowl grommet a little tighter but the leak is now worse. I've made a couple of grommets out of neoprene that I'll try today as an emergency measure but I'm going to order two sets of new ones. My fuel bowl risers that I machined took care of my fuel level problems so at least there is some improvement. I'm disappointed that the parts that Joe Curto installed leaked in such a short time.
jlaird
Might be the corn oil in the gas?
Nelson
Nelson
Joe is sending me a new set so I'll just have to try again. For the moment I have made a couple of washers out of neoprene and they are not leaking yet.
Platinum
Schmear some Hylomar on th' neoprene gaskets?
....just a thought...
Nelson
Nelson
Bill M. has already suggested that so it will be done.
Sopwith_Camel sap on my paint Spridgets 8
John_Mc Tree sap? Triumph 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
Walter74 Adjustable steering wheel removal Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T BJ8 Drain Channel Removal Austin Healey 2
D TR2/3/3A Facia removal steps Triumph 3
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Spitfire Triumph spit flange/hub removal Triumph 13
L TR2/3/3A Engine removal questions Triumph 8
7 paintless dent removal tools? Restoration & Tools 8
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
