Thanks for the comments Ron. Had to ask my wife what a renaissance man is and we decided it must be good. Be encouraged to have a go at the fabrication. Got to start somewhere and the product will be totaly your own.
Decided to look back at the firewall I put together some time ago to finish off the detail. At the time I didn't have a satisfactory way to spot weld or a supply of cage nuts so the holes and cage nuts needed to be done. Likewise lots of holes for steering columns and the like had to be sorted to facilitate conversion from left to right hand drive.
When I started to do the cut outs for the brake clutch assembly I decided to check the fit of the peddle box. Funny how time dulls your memory of the parts you have removed. I'm sure it was better than this when I took it off. Brings up the old question of refurbish or replace? I have decided the brake fluid container wil be replaced.
The supporting frame was a bit rusted so I decided to fabricate a new one. Made it from RHS which I had to cut down its length to adjust the width of the assembly from two inches to one and seven eigths inches. This was good because it allowed me to bend the flanges and then weld the two halves back together.
Unfortunately the peddle assembly was fused together with rust. The peddles pivot on a shaft which hangs in two bushes which are clamped in the frame. One bush turned in the peddle and the other was totally locked. Both bushes were eaten away with rust.
You can see the grooved bush between the peddle and the actuating lever. Unfortunately the bush is locked in place because the lever is welded on after the bush is put on the shaft. I decide I need to disassemble both peddles and replace the bushes. This required an angle grinder to cut the welds on the lever.
I turned up two new bushes on the lathe and then welded the levers back on the main bosses. Reassembled the peddles into the supporting frame. If you cross your eyes and squint you can see the new bushes between the peddles and the frame.
Finaly back to where I started from! Dry fitting the assembly to the firewall to ensure the holes are in the correct places.
Two days work! Maybe I should have bought one!
now to get back to my firewall.
