LionelJrudd
Pretty well finished the front apron today and cleaned it up. Found a small section that I will do a bit more hammer and dolly work on as I was cleaning the metal with rust converter. Had a couple of headlights and buckets they mount in that I scrounged from a local man. Correct ones for the job but not sure what car they came off. Still need some surrounds but plenty of time yet.
Finally worked up the focus to do the last bit that has been stopping me reassembling the scuttle / firewall. Needed to replace some of the cage nuts that hold the doors. They are difficult to do if trying to spot weld them rather than just tig them in place due to the restricted access for clamping the metal layers together. Ended up using a variety of methods including G clamps, bolts and nuts and the like. Welds not as good as usual due to the limited area of metal being welded and doing it from the cage nut side. Even so, the welds are solid and they will be enclosed and out of sight.
Next job is to weld in the kick panels and start reassembling the firewall to the scuttle.
