Radiator Fan Clearance
Skip & Lynne
How close is the fan supposed to be to the radiator, I reinstalled mine this evening and I have about 1/8 inch between the fan bolts and my NEW radiator. There was a 1 inch spacer behind it when I took the car apart and the radiator was torn up pretty bad. I am thinking about milling about 1/2 fron the spacer. Anyone have any ideas? Skip
Keoke
High, Skip, that is way too close I would shoot for at least 3/4" space up there. Normally no spacer is used behind the fan it attaches directly to the pulley. Incidently what fan are you using? Also make sure the engine tierod is adjusted correctly and all of its bushes are in good condition-Keoke
S
Skip & Lynne
Thanks Keoke; my car came with a 6 bladed fiberglass fan, if I install the fan with no spacer it hits the crank damper. I have a 6 bladed stainless fan but it will have to be trimmed slightly to clear the front cross member. I think I am going to put the spacer in the milling machine and take off 1/2 inch at least. My other car came with a 2 bladed fan that bolted directly to the water pump so I am going to have to change that one as well. Skip
Michael Oritt
Skip--
Is it possible that the radiator has somehow been mounted too far back, or is it non-stock in dimensions? You should have at least enough clearance between it and the fan to change the belt.
Dave Russell
Yoda - R.I.P
Skip,
Due to the flow characteristics of automotive fans, if the fan is too close to the radiator, there can actually be reverse air flow over some sections of the radiator. The greater the fan to radiator spacing, the more efficient the correct air flow will be. Having the fan as far from the radiator as is practical gives better fan flow through the radiator. 1.5" or more would be a good spacing. Increase the distance as much as possible.
Obviously, another consideration is that the fan blades flex forward, some more than others, under load & can contact the radiator if mounted too close.
S
Skip & Lynne
Thanks Dave I just had this thing recored and do NOT want it eaten by the fan. The new core is the same thickness as the old one it is just a 4 pass core. I am going to do whatever I need to get at least 2 inches clearance. Skip
S
Skip & Lynne
Thanks guys I took the fan spacer and milled off half of the thickness. This gives me about 1 inch from the crank nut and about 2 inches from the radiator. All new engine and trans mounts and all are tight with no movement. Just like an old airplane when you change one thing it changes about a dozen others. Skip
Keoke
/ubbthreads/images/graemlins/savewave.gif
Nah, all he has to do is set the trim tabs-Keoke--- /ubbthreads/images/graemlins/cool.gif
bighly
Skip,
Your pullys are still lined up ok? Belts wear fast if pullys are not lined up.
just thought I'd throw that in.
T. /ubbthreads/images/graemlins/cowboy.gif
S Installing a Radiator Fan Austin Healey 9
RJS TR4/4A Radiator Fan Shround Triumph 3
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
J BJ8 Radiator Fan Austin Healey 12
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
FlyingCat Spitfire Electric Radiator Fan Triumph 10
FlyingCat Spitfire Radiator and fan Triumph 5
JFS TR2/3/3A Radiator fan temp probe Triumph 3
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Superwrench Radiator Fan Guard BJ 8 Austin Healey 4
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
rjc157 Electric radiator fan Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
DanLewis Distance between mechanical fan and radiator core Spridgets 17
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
johnrip Wedge tr7 radiator fan Triumph 1
RJS Radiator Fan Bolts - need quick help Triumph 4
RJS Balancing a radiator fan[?] Triumph 18
AUSMHLY Check out this radiator fan Austin Healey 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
QuickSilver Radiator Cooling Fan MG 10
G Radiator - Fan - Coolant ? Triumph 4
QuickSilver Question On Radiator Cooling Fan MG 5
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
pjsmetana Spitfire Spitfire Radiator Fan Triumph 3
K radiator fan shroud Triumph 21
Mark Jones Radiator fan motor - rebuild? Triumph 4
6 Moss Recall: Tropical Radiator Fan Austin Healey 46
kyreb1862 T-Series Radiator Cooling Fan Switch MG 6
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
G Ron Davis aluminum radiator and Spal fan pics..... Triumph 9
T Wedge TR8 radiator fan recommendations Triumph 0
LastDeadLast Custom radiator and electric fan stuff. Triumph 3
Michael Oritt Wizard Radiator Austin Healey 7
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
