Question On Radiator Cooling Fan
QuickSilver
Currently here is what I have:
There is no connector on the wiring harness that plugs into the fan sensor, the wires are just jumpe dtogether. I want to solv ethis.
First, where can I get the male piece that plugs into the sensor?
Second, could the sensor itself be bad because when I rig up the wiring to connect to it, the fan does not start? All these types of sensors I've seen before always failed into making the fan run on as opposed to not run.
Thoughts, conjectures, rumors, hearsays, repudiations are all welcomed.
Platinum
The sensor is called an "Otter Switch" and fails to close at temp if dead/defective. It's a bi-metal temp switch. The end you seek for the wiring is likely going to be difficult to source but the prongs on the switch are round pins and matching should be somewhat easy with a switch in-hand at a RadioShack or other place with electrical/electronic components on the shelf. If the switch was by-passed, you can count on it needing replacement. The new one should come with a new grommet, be SURE to replace that as well. It's a snug interference fit which holds the switch in place and using the old grommet will guarantee it will slip out or be "ejected" at the furthest point from home.
tony barnhill
Great Pumpkin - R.I.P
Doc's absolutely correct about the connector....however, if your wires are connected to one another, closing the circuit, both your fans should run constantly....if they aren't you've got other problems.
The little 'thermostat' that goes in the radiator is easy to get (I have them on the shelf).
Platinum
I kinda read it as the fans come on with iggy and don't shut down. They shouldn't come on with the iggy when wired thru the Otter device umtil the temp hits 165~175F or so.
The usual bodge is to pigtail the wires after the Otter switch stopped working to preclude overheating.
QuickSilver
QuickSilver
The fans work when the wires are "shorted" together.
Thanks I'll saunter by AutoZone and see if they have it.
tony barnhill
Sorry - misunderstood.
Yep, fans should work on temp from radiator - regardless of whether the ignition is on or not....when it gets hot enough, they come on...when temp is cool enough, they go off....& even if the engine isn't running, they'll continue to run to cool things down.
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
H Red radiator guard reattachment question Austin Healey 10
2billydavies TR2/3/3A radiator question Triumph 27
T TR4/4A TR4a top radiator hose question Triumph 10
M Radiator drain plug question Triumph 5
D MK2 upper radiator hose question Jaguar 3
bridgener Radiator Shroud Question Austin Healey 9
Stinger TR4/4A TR4A Radiator Duct Question Triumph 7
toysrrus Re: "Frogeye" Radiator ID Question: Spridgets 7
T Radiator paint question Triumph 4
tosoutherncars Midget 1500 radiator question Spridgets 11
JPSmit Assembly Order Question #1 - Radiator Spridgets 1
6 Question re: Welch Brass Radiator Austin Healey 5
regularman Quick radiator question Spridgets 8
C TR2/3/3A TR3 Radiator question Triumph 2
JPSmit Radiator Question Spridgets 11
C TR2/3/3A TR3B Radiator.. A Quck Question Triumph 8
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
