Question - how to ship a tranny.
jlaird
Drain well.
Slip into a plastic bag.
Slip into an appropiate box.
Fill with packing material.
UPS?
What is the cheep way to do this folks. Who has done what and do you remember the cost?
Nelson
When Paul A. shipped my five speed to me he had the engine end bolted onto a 14 x 15 inch piece of plywood. It came UPS and in 2004 I paid $75 for packing and shipping.
mrsprite
Poke a few air holes so he (she?) can breathe! :smile:
I usually ship transmissions FedEx ground.....they seem to be the cheapest for me. Bubble wrap helps, but as long as it has some sort of packing material you should be fine. I use computer boxes, which are double walled, for added protection.
Shipping costs should be in the $60-$80 range, depending on how far it needs to go.
Rut
Jack, both ways work, but I've had the best luck bolting it to a piece of plywood and slipping a box over the top. Find a box that's long enough to accomodate the tranny and cut the plywood the size of the end, slip the box over the top and secure with staples, big staples. This end up stickers are good. I use FedEx ground a lot and they have an economy rate. I can ship 150 lbs and under from CA to AL for about $55. YMMV
Rut
Deleted member 8987
After my last shipment with UPS, insured, I canceled my account with them and refuse to ship with them. All my suppliers had either changed or have changed to FedUp or USPS.
Insurance with OOOOOPS means absolutely nothing, unless it's lost and you can prove from an invoice your cost.
I shipped a unit (not LBC) in original die-cut Styrofoam box, in a cardboard box, in a box twice as big filled with ghost peanuts, and they did the 10 foot plus drop test, and broke gears, lights, all sorts of stuff, and just claimed "improperly packed", even though that box had been around the world in at least six different shipments with no problem whatsoever.
Most stuff now goes USPS.
Faster, cheaper, no damage.
Dave
TOCG
Billm
I still send stuff UPS but I will NOT use one of those "UPS Stores" since they charge an extra 30-50% markup! If you take it to the UPS main office (delivery center) you don't pay the extra.
BillM
UPS across the country is about $70 right now, 500 miles is about $50.
Sarastro
Last time I shipped a pair of carburetors by UPS I had to sign a form saying that they were professionally cleaned and had no gasoline residue. It's possible that you might have to do the same thing for any auto parts that contained flammable liquids.
Whitephrog
Greyhound would be my choice as well.
That said I've had great luck at the UPS store. I haven't experienced any mark up at all.
I buy a box big enough to easily fit the gearbox in then build a wooden crate type structure that fits inside the box to it's exact measurements, and I make the gearbox bolt to the crate, so it can't jossle around. I use Fed EX ground for this, as they don't charge you as much for oversize boxs as UPS does, you probably hit the scales with box/crate/gearbox in the 80 pound range, the ribcage gearbox is just under 60 pounds. You can run a online quote at the FEDEX site, you'll need roughly the box size, the weight and the two zip codes involved.
jlaird
jlaird
Wow, Hap strikes again. Thanks guy.
Gota keep in mind that is for a full up ready to go case.
Some one disasembled the one I am going to get and left it that way.
Jim_Gruber
So Jack a 5 speed for Miss Agatha?
jlaird
jlaird
No no. a rib case.
equiprx
When I started my business, UPS gave me an account and shipping guidelines to follow. Within the first year, damaged shipments amounted to over $4000 and UPS did not reimburse one cent. Since I fired them and switched to FedEx Ground, less damaged goods, and very fast reimbursement for damage.
I was forced to eat all the cost of damage or reimburse my customers and in some cases lost business which was the worst part of the outcome. If a customer want things shipped with their UPS account, they have to assume the risk of loss or damage. After I tell them that, they usually ship with FedEx.
The only thing UPS has going for it is the drivers are really nice guys, never rude, rushed or careless. Since the company went to employee owned, management is destroying the company.
Dave
TOCG
Here is an off topic question. My wife paid a hefty premium to UPS to have something overnighted. The package was a day late due to weather delaying and rerouting flights. Makes sense. So, she requests a refund on the overnight premium. They say "nope not our fault". What kind of customer service is that? She was just asking for a refund on the part of the service they failed to provide.
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
Lin Ignition timing question Spridgets 2
Lin Oil sump sealant question Spridgets 0
D TR2/3/3A Another Carb question. Triumph 22
Sarastro TR4/4A Differential setup question Triumph 12
T TR2/3/3A Question on old radio from my TR3 Triumph 9
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
H GT6 ...and a basketweave seat cover question Triumph 2
Lin Heater water valve question Spridgets 2
RJS General TR Wire Wheel Spline Question Triumph 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
D TR2/3/3A rearmost fuel line question Triumph 5
jlaird MGB This weeks werd question regarding steering racks. MG 3
nichola TR6 Question on new wiring harness Triumph 6
JPSmit Today's question - vacuum advance Spridgets 2
B Rotisserie question Spridgets 4
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
JPSmit Electricity question Restoration & Tools 3
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
JPSmit todays's job - and a question Spridgets 25
Y TR6 SU HS6 question Triumph 1
B TR6 TR6 1976 Clutch Choice Question Triumph 3
P '58 XK150 Dynalite Alternator swap question Jaguar 0
glemon TR2/3/3A Crankshaft Question Triumph 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
Lin New Forum Upgrade Question Austin Healey 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
jlaird MGB Strange daily question. MG 10
F TR2/3/3A Floor pan question Triumph 16
F TR2/3/3A Bumper bracket to frame question Triumph 7
Simmo General Tech Electrical question Triumph 4
T TR4/4A Surrey top question Triumph 18
JPSmit Vauxhall question - I know, weird eh?! Lotus 6
S TR2/3/3A C39/C40 question Triumph 7
nichola TR6 Seat belt reinforcing plate question Triumph 15
J TR6 TR6 Differential Rebuild question Triumph 6
D Tri carb: order of installation question. Austin Healey 5
C MGA Mirror question MG 0
JPSmit Todays question - wiring Spridgets 14
P TR6 1970 TR6 Timing Question Triumph 2
Lin Another Trafficator/Control Head Question Austin Healey 10
Lin Brake hard line question Austin Healey 4
J TR6 Vacuum Retard question Triumph 1
tahoe healey Dumb carb question Austin Healey 23
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
J TR6 Moss HS6 SU conversion kit question Triumph 4
Lin "A" Pillars: A Question Austin Healey 8
D TR2/3/3A Overdrive question. Triumph 49
Lin Thermostat and blanking Sleeve question again Austin Healey 7
