Hello -
The prior owner of my BJ8 switched the wires on the sports coil, which I believe affects the polarity to negative ground? I recently switched the wires back. Now the car occasionally stalls while I'm driving, which it didn't do before. If I catch it fast enough, I pump the gas pedal and that usually alleviates the occurance.
Otherwise, the car will start back up, usually on the first try.
Any idea what this can be from?
Thanks for the help!
