You guys have been a great resource as I work through all that goes along with being a new Healey owner and without the wealth of information here I never would have been able to rebuild my carbs, clean my trafficator, tune the engine or understand and maintain my BJ8- a big thank you. But I’m hoping you can help me understand one thing I just can’t get my head around even after reading hundreds of posts on the subject- the importance of polarity.
I understand that for some things like incandescent lights polarity doesn’t matter- electricity can flow through the filament either way and the light will work.
I understand for things like diodes in the fuel pump, polarity matters and current must flow in the correct direction- so when reversing a car’s polarity the fuel pump will not work unless you also reverse the diode.
What I can’t understand is why on items that care about polarity (like an electronic ignitor) you can’t simply reverse the wires on the item and be done with it- it seems to me that reversing the leads when converting from pos to neg ground would cause the electricity to flow the intended way through the item without blowing the device or needing to fuss with diodes. Clearly I am missing a basic principle here, but I just don’t know what. I get that if one item is pos. ground internally and another is neg. ground internally that having the grounds touch can create fireworks (such as is discussed in all the “isolating a cigarette lighter” discussions) but I don’t get why you simply can’t reverse the leads when going from pos to neg ground- so long as the power and ground are on the wires that the device was built to carry them on I would think there would be no issues and the device would just work when the car is fully converted to neg. ground.
I know I’m missing something really basic here, but I’m no electrician and I’m barely a car mechanic, so any tips on how to get this straight in my head so I don’t fry something important would really be appreciated.
Thanks,
Chris.
Thanks,
Chris.
