I started doing some calculations about this. I'm hoping someone can correct me before I make an expensive or stupid mistake...
I *think* that if I switch to a 17" wheel, a 17x7 will fit. If a 16x7 fits, then a 17" one ought to, right?
If the 16" is zero offset (a la Panasports 16x7) then a 17" one the same width ought to be the same, no?
Armed with these suppositions, and the fact that the wheels from a 240z are supposed to have the same size bolt pattern (by extension it appears a 260 and 280z also are the same).
17x7 seems readily available for z cars, so it's just a case of making sure the offset is correct, no?
Now the really cool bit - If I use a 205/60/17 on a 17x7 then the size is really really close to stock (assuming 80AR on stock).
If it's this easy I must have missed something, but what?
/ubbthreads/images/graemlins/england.gif
