The book says the generator light is the same bulb; AFAIK that is correct.
You can't really judge bulbs by their "cold" resistance, because it changes dramatically when the bulb lights. For example, 6.5 ohms would mean the bulb draws nearly 2 amps and dissipates over 20 watts! But when it heats up, the resistance goes up as well, so they are only about 2.2 watts. Also, the resistance (both cold and hot) goes up as the bulb ages.
That's interesting that you found a 1449 bulb rated at 12 volts. Usually, that bulb number is rated 2.8 watts at 14 volts.
Just as a side comment; the output of incandescent bulbs always goes down as they age. The rated numbers are a "nominal" value; generally the bulb will be brighter (and more power) than rated when it is new, and then drop below nominal before it actually burns out. The old Lucas bulbs seem to be particularly bad about this, I have seen original bulbs that still "worked" but the glass was completely black and the bulb put out almost no light at all. What happens is that the metal of the filament literally evaporates, making the filament thinner (hence higher resistance and less power); then plates against the inside of the bulb (further blocking light output).
