T
Tinster
I think I need some diagnostic help with my lack of turn
signals. Remember, all four turns lights went dead while driving. But all four emergency flasher lights worked just fine. Since then:
1. I installed a new blinker can.(old one works fine)
2. I pulled the new turn signal switch and looked for
rust-none observed. Switch probably used less
than 20 times.
3. I cleaned all the spade terminals on the hazzar switch .
4. I installed all new wires from the Power Block into the
dash and into the turn signal switch and into the hazzard
switch.
5. Tested turn signal wires circuit to lights with portable
12V battery. All lights functioned.
6. Measured 12V going INTO the turn signal switch.
7. Measured 12V going INTO the hazzard switch
After all that I have exactly the same condition. Emergency flashers work perfectly when I flip the switch.
The turn signal blinker can makes a blinking noise when I
move the signal switch arm up or down, but all four turn
signal lights remain dead.
The turn signal switch and hazzard switch are both brand new.
I'm stumped. Any ideas?
thanks,
dale
I am really puzzled with the blinker can blinking but no lights blinking. The blinker can must be completing a circuit somehow or it would not blink-is this correct??
But my 4 ways work properly.
than 20 times.
switch.
thanks,
dale
