TR4/4A New Radiator
KVH
The new aluminum ones have come down in price. If I buy one will I really notice any difference or will I still overheat at Arizona summer red lights? (assume I'm properly tuned:friendly_wink:smile:
Will I still want an electric auxiliary fan?
TR3driver
Great Pumpkin - R.I.P
IMO new aluminum isn't much better than new brass as far as cooling. So how much improvement you see depends a lot on the condition of your old radiator.
Also IMO, you shouldn't be overheating at red lights, unless they are unusually long or you have just stopped from driving hard (eg 70 mph on freeway, then stop for several minutes at the end of the off-ramp). The gauge will creep up while sitting stopped, but not fast enough to boil over during a normal red light. (Stop and go traffic is a different problem, though.)
But the electric fan is probably still a good idea. I hear traffic jams happen even in Tucson :smile:
Geo Hahn
The only people who think Tucson has traffic are the ones who never lived in SoCal.
Almost anything you do in the fan department will be an improvement over those butter paddles STC used for fan blades.
For years I used manually controlled electric fans - effective but I always wondered if they blocked significant air when off & driving at speed. Figured it was a trade-off worth taking.
More recently (after throwing a couple of original fan blades) I went with an improved crank-mounted fan. I use the TRopical Fan but many alternatives are also out there. They are so effective I ditched the electrics.
charleyf
I switched to the aluminum radiator plus the yellow fan and like the result. Our temperatures here rival those in AZ with 110+. They go higher but I seldom drive when it is hotter than 110.
Charley
TR3driver
As a side note, I use only an electric fan, mounted as a puller. I finally built an automatic controller that works, but ran for many years with only a manual switch, first 15+ years on my previous TR3A and then on the current TR3. I tried keeping the stock fan with the TR3, but it got hot coming home from TRfest 2009 (big traffic jam on the 101, almost 2 hours to go 30 miles) and I decided to go back to the electric setup from the 3A.
Although powering it can be an issue (I'm still running the original 19 amp generator, you should have the later, larger unit) I really like the result otherwise. The fan never comes on at speed, only when I stop suddenly (eg freeway offramp) or I've been sitting at a light for more than a minute or so. Running a 185F thermostat (no sleeve and bypass fully open), and the gauge never goes above the '5' in '185' (which is where I have the fan set to come on).
115F is about my limit as far as ambient temperature goes, but the engine stayed cool. And I really like no longer having to keep one eye on the gauge all the time.
It's my belief that the electric fan poses significantly less restriction mounted as puller instead of pusher; possibly even less than the engine mounted fan does. As a puller, the fan freewheels at higher speeds, allowing the air to pass with relatively little restriction.
But my experiment with the Stag seemed to show that mounting the electric fan in front of the radiator reduced air flow at speed. Might not apply to all cars, and YMMV, but it ran hotter at speed with the electric pusher than with either the stock crank-mounted fan or no fan at all. (I went back to stock as soon as I could find the necessary replacements for the broken parts.)
KVH
KVH
Randall are you saying that you have no fan working when driving at speed? No stock fan, and not even an electric fan unless and until you reach 185 when the switch kicks in?
TR3driver
Yes, exactly. Well, except that the fan doesn't come on until the water coming back from the radiator is about 190F :smile:
At anything above about 30 mph, no fan is needed. The "ram air" effect moves enough air through the radiator without the fan. In fact, I once drove a TR3A through most of an Indiana summer with no fan whatsoever, just by turning off the key (and coasting) every time I had to stop. Annoying and tedious, but better than walking ! I wouldn't try that in Los Angeles traffic of course, but things were different back then in small town Indiana.
PS, even when sitting still, the electric fan does not run constantly. Obviously the times vary with ambient temperature and so on, but it usually only runs for 40-50 seconds and then shuts off for 20-30 seconds. One of my future projects is to build a fan controller that uses PWM (pulse width modulation) to only run the fan as fast as necessary. I think that will reduce overall power consumption as well as reducing noise.
HarryL
When I rebuilt my 4A I thought about the aluminum rad. vs. having the existing one re-cored.
Used aluminum on my race cars for a weight advantage. Took the old one to a reputable shop in
the area which also redid my fuel tank. Could've lived with the results; but didn't like the way the temp.
went up during the usual traffic jams. Went with the Macy's fan and had my problems solved.
Harry
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
D BT7 radiator Austin Healey 1
M Radiator Paint Austin Healey 20
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
JFS TR2/3/3A Radiator fan temp probe Triumph 3
