Woodie
Ok let me describe this again, cause I am getting no where fast (literaly) I have a 1275. 1970. It was recently running fine, with no airfilters on it. Drove it about 1/2 mile two or three times all seemed fine, oil pressure is good, temp is 1/3 up the scale (half way between the C and N). The car starts fine. I have cleaned the carbs and bowls filled the dashpot. The timing is set by ear( sorry cannot find the timing marks on the pully wheel) and am not skilled enough to set static timing. The timing cannot be to far off, as it ran fine. Now, I put on air filters, and she runs like do do. No power, miss fires, runs rough during acceleration and then sort of coughs(slight mis fires )while cruising. I can solve the poor running by pulling the choke about 3/4 of the way out and leaving it there. ANy suggestions....
