Milky oil?
TR4
Pulled my TR4 valve cover off today and there is a slight coating of milky oil at one end of the cover and a little bit on top of the head. Seems to be a blown head gasket, right? Would it hurt to run the motor for a while to tune in the carbs or shut er down and pull the head?
SkinnedKnuckles
Not so fast there. Is the dipstick oil "milky"? Combustion gas contains lots of water vapor, and the gas that blows by the rings and slips past the valve stems exits out the valve cover, right? It could just be that a little condensation in the valve cover mixed with some oil. This would be prone to happen if you don't drive alot of miles when you take the car out since it may not get hot enough long enough to re-evaporate any condensation. If ALL the oil is milky, then you have a problem.
vettedog72
Is that the only symptom; no other indications? I would do what ever you took the rocker cover off for. Is it skipping or running hot? If it is not running hot, I think you could run it as long as needed.
TR4
TR4
I have only run the car for 5 mile laps throught the winter when the roads were clean. I went ahead and fired it up and went through tuning of the carbs, then checked the oil again and it seems fine. Must have been condensation like you suspected. I run 30 weight oil and since spring is near, I'll change it out again. I do change just before winter too. Thanks guys!!! /ubbthreads/images/graemlins/thirsty.gif
prb51
It's not uncommon to fine some contamination in the valve train area from condensation and engine breathing etc. I have found this in my other older cars without any problems. If you don't have this same issue in your sump or radiator you are probably ok.
Webb Sledge
I don't know if you're rebuilt your engine or not, but it is possible to have a bad bearing where you'll find a minute about of grey babbit in the oil as the new bearings wear in. I had this problem, which went about after a few miles. The real place you need to be conserned with, like prb51 said are the oil sump and radiator. Any milky white stuff on the dipstick or black in the radiator and you're got yourself a problem.
D Milky White Gooey Color in Oil Austin Healey 11
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
