MG engine swap
edr
I'm working on a 58 MGA. Not nice enough to make a show car but will make a good driver. I have a 72 B 1800 engine I'd like to put in it. Can anyone help me with what is needed at the flywheel, bell housing? Are the rear plates interchangeable? Thanks for any help Ed Ryan
Geo Hahn
Ed - you might get an answer here but perhaps more responses on the MG portion of our show (go to 'Forums' and select MG).
Banjo
I believe it's a straight forward bolt in swap, but like geo said try the MG forum
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
A Bugeye engine swap, 948 to 1275 Austin Healey 11
drooartz MGB Stuck in now, engine swap time MG 13
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
JPSmit Loosely contemplating an engine swap for Ms Triss Spridgets 14
Rut Engine and 5 speed swap Spridgets 2
Kleykamp TR2/3/3A Engine swap and Separating Trans from Block out of car? Triumph 5
B Engine Swap Spridgets 11
7 Engine Swap Triumph 2
B Wedge TR7 Engine Swap Triumph 12
J Engine Swap question Spridgets 25
5 BE engine swap Spridgets 6
H Post-War Other Herald Engine Swap Triumph 4
M Need Engine Swap Ideas for '76 Midget Spridgets 21
ChrisS Engine Swap British Motor Corp 3
mailbox Disco engine swap Rover / Land Rover 3
billspohn Interesting Engine Swap MG 8
Jayrz Prettiest Engine Swap I've seen! Spridgets 7
H Engine swap Triumph 15
jackq B engine swap MG 1
Branson one heck of an engine swap! Spridgets 13
Branson interesting engine swap Spridgets 20
J Bonnet Removal for Engine Swap Spridgets 9
LeeMcKee Engine swap and frame color? Triumph 6
S mazda engine swap MG 5
E MG engine swap MG 1
S engine swap British Motor Corp 4
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
S engine swap issues Spridgets 25
G engine swap MG 2
J Wedge TR7 engine swap Triumph 17
K miata engine swap MG 85
L engine swap MG 7
nathandarby67 Head swap for 1275 engine? MG 4
61Alpine Alpine V6 Engine Swap Sunbeam (Rootes) 15
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
