Left over piping from trim panel kit
rggav
Member
I just installed a Moss trim panel kit on my 65 MGB. I received some small red piping and some large black piping with the kit. What do I do with this piping....no instructions on where to install it?? By the way the new black with red stripe trim panels look great.
Shinsen774
Is that for the dash and the rim around the back of the cockpit where it meets the rear cowl?
rggav
rggav
Member
My car didn't come with the metal rim on the rear cowl. I just bought it and installed it before I received the trim panel kit. I guess the piping with the larger attached vinyl goes around the metal band with the small round piping cord up or down?? I don't where you would install the red piping on the dash. Has anyone installed the trim panel kit.
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M Left shock Spridgets 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
Martinld123 My left rear wheel is locking up Austin Healey 16
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
M Wanted Bj8 left front wing Austin Healey Classifieds 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
Tosh TR6 Engine dies slow left turn. Triumph 26
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
F BN7's left Austin Healey 9
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
C Left to right hand drive Austin Healey 2
Lotus Club SoCal Left Coast Octoberfest Lotus 0
T Wanted TR6 Left Taillight Housing Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
Boink Left-hand Drive E-type at Windsor Jaguar 5
John Turney Left Rear Shock Mount Austin Healey 5
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
Popeye TR4/4A Seats - left/right Triumph 8
C TR4/4A left brake lamp not lighting TR4A Triumph 4
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
P TR6 Left direction signal no work Triumph 15
D 69 E-Type sputters when making left hand turn Jaguar 6
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
M TR4/4A Left lower dash crash pad. Triumph 5
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
K TR2/3/3A Pullsl to the left when accelerating? Triumph 9
AngliaGT What Goes to the Left of the Tach? Spridgets 3
D Problems with left rear turn signal Austin Healey 11
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
C Pulling to left Spridgets 8
I TR6 Left wheel gets warm when I drive Triumph 8
P TR6 sagging left side Triumph 4
