Greetings!
I just purchased a 61 MGA, my first British car. (Up to now its been VW) The electric fuel pump would run when I turned on the key, then shut off when the pressure filled, but never start back up again. I could only run the car for a minute.
I hadn't found this great site yet so instead of asking for help I bought a new pump from Victoria British.
I hooked up the wires like I think they were before. A red wire and a green wire on the top post and the +ground wire from the side of the pump base to the car frame. Turn the key and no juice to the pump. All other electrical is working OK.
I've only found two fuses and they are on the fire wall inside the engine compartment, above the engine. Is there another location I should be checking for fuses?
Does it sound like I hooked up the new pump correctly?
