Inertia Switch
als
Can someone point me to a supplier who carries inertia switches for electric fuel pumps. I have the pump, but not the switch. I have not been able to locate a source. My car is a 76 Midget.
Thanks
Al /ubbthreads/images/graemlins/canpatriot.GIF
Tim Hollister
Al,
Check eBay! I'm in a hurry to get out the door on the way to work so I didn't save the item number but go to eBay Motors and do a search for "inertia switch." The last item that came up on the search I just did was a BMC/BL switch for Enlish cars from 1974 on!!
Best wishes!
Tim
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Gliderman8 TR6 Inertia switch location Triumph 9
Gliderman8 TR6 Inertia switch mounting location Triumph 4
steveg Fuel pump inertia cutoff switch Austin Healey 33
GTP1960 TR2/3/3A Fuel pump inertia switch vs. dead engine switch? Triumph 14
B T-Series Fuel pump inertia switch? MG 4
glemon T-Series MGB Inertia Switch MG 13
J TR6 Inertia cut out [off] switch TR6 Triumph 9
Z T-Series Inertia fuel cutoff switch MG 7
Z Fuel inertia switch Austin Healey 3
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
H TR2/3/3A SECURON INERTIA SEATBELT ON TR3A Triumph 5
B Inertia, Ennui Triumph 30
Daimlerdb18 How to overcome restoration inertia MG 30
M TR6 TR6 inertia seat belts Triumph 8
B inertia reel seat belts Austin Healey 1
F Wanted Foot Dipping switch Triumph Classifieds 0
K TR2/3/3A Dimmer switch.....any electricians out there? Triumph 5
M TR6 Mystery Switch Triumph 0
H MGB 1980 mgb no power from ignition switch MG 23
Gliderman8 TR6 Handbrake warning lamp switch build Triumph 14
O Ignition switch / steering lock replacement in a '78 midget Spridgets 4
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
longbridgehealey Bugeye combination switch Spridgets 2
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
longbridgehealey Bugeye ignition switch Spridgets 4
T Bug Eye Heater Switch Help Spridgets 2
A BN1 Mechanical Brake Switch Austin Healey 23
P TR6 identifying switch Triumph 3
P TR2/3/3A TR3B Panel Light Switch Triumph 20
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
R TR6 Thermostatic vacuum switch Triumph 3
D TR2/3/3A Brake light switch. Triumph 22
Gliderman8 TR6 Hi-Lo light switch....... Good to have spares Triumph 1
P Broken Overdrive Switch in Gear Knob Austin Healey 14
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Boink Brake Light Switch... Spridgets 4
M TR6 Turn signal switch stalk Triumph 1
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
Upland 3 position headlight switch is now 2 Spridgets 1
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Help 4
TRMark T-Series brake switch MG 7
TRMark T-Series Horn/Dipper Switch MG 4
