Impact drivers, and proper use of same
jlaird
Put screwdriver portion in fitting, turn body of driver all the way in the direction you wish to turn fitting. Hit smartly, repeat.
My brain did not remember but my hands did, when I tried to use impact wrench they remembered, strange.
Morris
Way off topic, but what you are describing is a much discussed and studied phenomenon as of late that leads some scientists to believe that our consciousness and memories are not as centered in the brain as we once thought. It's fascinating stuff.
tony barnhill
Great Pumpkin - R.I.P
You're just spending way too much time in the garage, Jack! hehehehe
jlaird
jlaird
Tony, I am not spending enough time in the garage at all. My back is still not right and it is a son of a ....... with that little car just setting there. I want/need to get to work but it hurts and guess it won't get better unless I rest it.
So much to do and so little time, well lots of time but I am wasteing it.
The time you enjoy wasting is not truely wasted time.
...a quote from somebody
tony barnhill
Jack - have you met Janel?
(I'm funnin')
jlaird
jlaird
Hmm, Janel thought I had it wrong.
Have not met but would like too, seems like good folks.
jollyroger
First you have to hit yourself really really hard with the hammer. That is the first rule for impact drivers. Blood first. Then it may work after that.
[ QUOTE ]
... That is the first rule for impact drivers. Blood first. Then it may work after that.
[/ QUOTE ]
I think of it as lubricant.... /ubbthreads/images/graemlins/confused.gif
The car thinks of it as a sacrificial offering.... /ubbthreads/images/graemlins/devilgrin.gif
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
TomMull Harbor Freight "Earthquake" impact wrench Restoration & Tools 10
TomMull cordlesss impact wrench, pricey but... Restoration & Tools 4
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
C Color change...impact on Value? Austin Healey 24
glemon Major impact to the hobby Restoration & Tools 3
T Impact wrench question Triumph 12
T Impact of running a 3.9 differential in my Bugeye Spridgets 21
RJS Oil Filter Impact on Oil Pressure? Triumph 15
T What impact, if any, from floppy PCV neck Spridgets 6
weewillie electric impact wrench Restoration & Tools 18
Jim_Gruber Wheel Bearing Grease/ Impact wrench on hubs Spridgets 11
Jim_Gruber Impact Wrench and Air Hose Size Spridgets 6
1965_MGB cheap electric impact at HF Restoration & Tools 3
J Use of an electric impact wrench, little off topic Triumph 10
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
HealeyRick Healey Drivers at F1 Montreal Austin Healey 2
DornTRoriginal TR2/3/3A Tub gap between Frame Drivers side Triumph 3
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
HealeyRick What Healey Drivers Look Like Austin Healey 21
K TR4/4A Any daily drivers? Triumph 8
CJD General Tech The Story of New Drivers Triumph 12
T 100S Drivers Handbook Austin Healey 8
charleyf TR6 Plate on drivers side front inner fender Triumph 6
K MG Midget rear drivers side spring sag? Spridgets 7
F XKE SIII Drivers Door Mirror Knob Jaguar 1
maxwedge5281 drivers side 4 inch vent hose Austin Healey 5
DNK Wedge Traggic Day for 2 Holland Drivers Triumph 11
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
T Question on removing drivers front lower wishbone Triumph 7
aeronca65t MG Drivers MG 0
Marvin Gruber T-Series TD or TF drivers door handle needed MG 9
Patrick67BJ8 Drivers Floorplan Dimensions needed Austin Healey 13
dougie The Drivers - TV Series Racing 1
R BE Drivers Seat Spridgets 2
af3683 TR2/3/3A TR3 Drivers Side Defroster Vent Triumph 11
jlaird Drivers Handbooks Spridgets 11
M Drivers seat setback Austin Healey 2
M 1985 XJ6 Drivers door lock Jaguar 5
Marvin Gruber Drivers side vent glass BJ8 Austin Healey 2
jlaird Put the drivers seat Spridgets 4
PeterK Central Maine Triumph drivers Triumph 28
IanF Spitfire Clutch question for Spit drivers... Triumph 13
V Older Triumph Drivers may remember the days Triumph 19
davidk Drivers seat is too wide! Triumph 4
B Up-dated Pics! completely restored the drivers seat Spridgets 16
