Ignition Switch / Steering Lock Removal Question
Monark192
I need to replace the ignition lock on my 74 Midget. The lock/switch assembly is help on with anti theft bolts. What is the prefered method of removing these bolts??
Thanks.
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
P TR2/3/3A ignition switch smoking Triumph 12
C TR6 Ignition Switch for 1972 TR6 Triumph 1
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
H MGB 1980 mgb no power from ignition switch MG 23
longbridgehealey Bugeye ignition switch Spridgets 4
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
L TR6 1974 Tr6 ignition switch Triumph 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
S TR4/4A Ignition switch key position Triumph 2
J ignition switch, On but no starter at all times British Motor Corp 2
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
S BJ8 Ignition switch? Austin Healey 7
AngliaGT Ignition switch/Wiring Diagrahm..... Spridgets 0
AngliaGT Midget MKIII Ignition Switch Spridgets 0
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
rjc157 ignition switch Austin Healey 5
RedTR3 TR2/3/3A Ignition Switch Triumph 4
Gliderman8 TR6 Installing new ignition switch Triumph 7
RickB I was wrong. Again. Not ignition switch! Spridgets 16
longbridgehealey New Bugeye ignition switch question Spridgets 10
longbridgehealey Bugeye ignition and light switch Spridgets 9
Rut Bugeye light-ignition switch Spridgets 6
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
G T-Series Ignition switch MG 10
B ignition switch Spridgets 5
M TR4/4A TR4A Ignition Switch Circuit Triumph 3
G T-Series Tachometer and ignition switch MG 16
T Ignition switch Triumph 6
D T-Series Access to ignition switch '68 MGB MG 9
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
V Removing ignition switch assembly. Spridgets 2
BugeyeNJ58 Ignition Switch and key Cylinder comes apart! Spridgets 0
72_TR6_Oceanside Ignition switch wiring order help Triumph 16
O TR6 1971 TR6 Ignition Switch Swap Triumph 1
