How can you tell if a starter is good?
ichthos
Is there a way to check a starter to see if it is good? Is it as simple as just hooking up jumper cables? Thanks, Kevin
jlaird
Ahhh, the engine runs after use. Sorry.
Take it to a parts store and have it tested,
jvandyke
I did. Both through the solenoid to make sure that's engaging and if not, direct to starter lugs to make sure it spins. Easy to take apart, clean up, check brushes, renew if worn, reassemble and voil'a you've got a rebuilt starter, for the price of brushes (if needed) or free if not. I pulled my Fiat starter and did just this, went from inop to working fine all summer for free. Parts places will check for free if feel like hauling it down there. If the commuter is shot well, then it's done but that's rare I believe.
spritenut
When you hook up jumpers to a starter, hook up 1 to the brass terminal and use the other lead on the starter ear (ground) as to not arc or melt the hot terminal.
And be warned it will jump (if it works) when you hook power to it so hold it tight.
MikeP
Also look at the condition of the drive gear, I've seen them where the teeth are badly worn and that can be hard on the ring gear.
I
ichthos
I actually had two concerns. I wanted to know if the starter actually worked to begin with, which I found it did. Secondly, I had to replace the ring gear because it was badly chewed, and was concerned as to why. The starter teeth look fine, so I am not sure what the issue was. It could have been chewed up and the PO put in another starter after the fact.I guess I will find out when I start it up. Thanks for the help.
Kevin
MikeP
Sounds like the case. When it stops working the first thing many folks do is throw a new started at it. I'd bet that if you were to see it the PO had a starter with chewed up teeth on it that came out of the car.
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
L Can anyone tell me what car this is from please? Other Cars 0
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
J anybody tell me why this thread closed? Austin Healey 4
matmire Curious if these photos tell you anything about my car. Spridgets 24
Boink You tell me... Spotted 3
D Bumpers and over riders, How do i tell if they are replacement or not Austin Healey 5
J How can I tell if I have a negative ground tach? Austin Healey 5
J How can I tell Austin Healey 1
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
JPSmit Viva GT show and tell - and a question Other British Cars 4
M gotta tell somebody Spridgets 10
J How to tell if your car is from the South... Spridgets 15
rkep01 How to tell if lever shocks need rebuilding? Spridgets 3
I How can you tell if a transmission is good? Spridgets 2
S Oh the stories this car could tell! Jaguar 1
M Tell me I need a fuel tank sending unit Spridgets 21
jlaird Miss Agatha was trying to tell me something Spridgets 4
T How tell if gear reduction start fits is right? Triumph 2
R Austin but can some tell me what model, please? Spotted 5
I Can someone tell me what these are? Spridgets 12
drooartz Manifold vs carb vacuum - how to tell? Spridgets 18
T Why don't you guys tell me this stuff ;-] Triumph 10
F Compression test: What does it tell me Spridgets 6
T How tell if wire wheels are good? Triumph 7
T Can you tell what kind of car this is Triumph 9
R How do you tell if a rim is bent or warped Spridgets 1
T How tell if a used radiator is good Triumph 14
R Tell me this is not a big deal Spridgets 7
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
DrEntropy We're havin fun NOW I tell ya!! MG 26
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
JPSmit Show and Tell - new carpet & progress Spridgets 44
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
theleisure Silicone or Synthetic, How to Tell Spridgets 5
CCURTISS How to tell if paint is Enamel or Lacquer??? Restoration & Tools 7
I How can you really tell how old a tire is? Triumph 22
bthompson My turn for Show and Tell! Spridgets 12
kodanja Tell your worst TR horror story! Triumph 45
T Quick - tell me about your TR driving big miles Triumph 25
mrdibbles How to tell what year your Healey is? Austin Healey 14
58Custom How to tell diff btwn 1275 speedo & 1500 speedo? Spridgets 13
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
AngliaGT How to Tell if an OD Trans MG 2
tomshobby show-n-tell Triumph 8
N MGB How does on tell if an MGB has Overdrive MG 7
