How tell if a used radiator is good
tdskip
So I just pulled the flushed and flushed TR6 radiator on the '74 and after a bit of flushing/back flushing I have water flowing freely through and no rust coming out. I don't have any history with the car except running it around the block, and am trying to balance getting it recored/upgraded vs not throwing piles of money at it.
What say you?
Re: How tell if a user radiator is good
That's what I did with mine, then I put it back in the car. I did have enough history with the car to know it didn't leak.
Pressure testing isn't too hard. Duct tape over the big hose outlets and rubber tipped air pressure hose on the drain valve hole. Squirt merrily with soapy water and watch for bubbles. You neither need nor want a lot of pressure.
It's 95 here today, and while it's running hotter than 185, it ain't boiling over...
I've been though heck and back with radiator flushing and repairs. It just never seems to work out for me. When I did the TR3 resto, I KNEW that the old radiator was in decent shape, as it came from a running car that didn't have any over heating problems. But, I still bought a new one. I might have taken a gamble if access to the radiator was easy, but on a TR3, you have to remove the nose.
If you don't know what the condition of the radiator is, a new one is sometimes the best alternative. Having said all of that, since pulling out the radiator in a TR6 is a piece of cake, stuff it back in. But, if you have ANY problems, chuck it and get a new one.
I'd agree on a TR6.
But FWIW on a TR3 where the R&R of the radiator is a Promethean task I'd do everything reasonable to check it out before putting it back in.
For a TR6 (where the radiator R&R is relatively simple), I'd probably just put it in and try it.
FWIW, on the project '3, almost the first thing I did was take the radiator (which had already been recored) to a radiator shop. They pronounced it 15% blocked, so I had them rod it out and pressure test it (which wasn't all that expensive, maybe $60).
Once in the car, it seemed to work well at first, but soon it started overheating. Apparently there was crud trapped inside the engine block, that came loose and clogged the radiator. Took a major backflush (full garden hose pressure plus compressed air) to get most of the crud out. After that, it went back to working fine again.
But I took it out again last night (for an unrelated reason) and found that it appears to have a tiny leak on top (where it's hidden by the front apron), so it's back to the radiator shop with it.
Aloha,
I addition to not leaking and being free of crud and any blockage, it is important to inspect the fins. If the fins are deteriorated or not connected to the tubes between the upper and lower tanks the radiator will have poor cooling. Those fins transfer the heat to the air passing through the radiator. Re-coring a radiator in otherwise good condition (especially a brass one) is less expensive that buying new.
Yup. I went through that with the TR3A. The original radiator was a rather odd construction, with the tubes pushed through holes in the fins and not soldered. Apparently mine were no longer in good thermal contact, so even though the radiator didn't leak and flowed just fine, it didn't cool worth a darn. A recore did wonders.
Recores aren't always cheaper it seems, but I have to wonder about the quality of complete new radiators that are cheaper than just a core. I got a Modine core that, as it happened, has outlasted the car.
I had mine recored and pressure tested to 22PSI; should be enough for a 4PSI system. The heater core is an unknown, but no signs of leaks - yet.
To answer the question:
1. have it boiled out to remove all the build up inside it (this will unmask
any potential problems)then-
2. proper pressure test-I like 30 lbs min-if there is going to be a problem,
this will expose it.
Rob
If you are wondering about "where", Skip, I heartily recommend Mac's Radiator in Bellflower. I've been dealing with them for over 25 years and they've always treated me right. Not particularly cheap, but they do good work and stand behind it.
https://local.acdelco.com/ACDelcoDMA/TSS.aspx?id=673094
Sage words that have been written before:
<span style="font-weight: bold"><span style="font-style: italic"><div class="ubbcode-block"><div class="ubbcode-header">Quote:]The heater core is an unknown, but no signs of leaks - yet.[/QUOTE]</span></span>
Flush and test carefully as the fluish chemical can cause a leak in a weak or corroded component
Thanks guys. Unfortunately I'm a bit away from Bellflower Randall, but I've hear you (seen you?) recommend them before and it is good to have a referral if I need a re-core.
Thanks!
So I picked up the radiator today and it turns out that despite having been re-cored at some point it was like 40% blocked. Everything was checked and it passed a 25psi test just fine, so I think I'm good to go for a while.
Bringing it in was a very good call - thanks guys!
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
L Can anyone tell me what car this is from please? Other Cars 3
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
J anybody tell me why this thread closed? Austin Healey 4
matmire Curious if these photos tell you anything about my car. Spridgets 24
Boink You tell me... Spotted 3
D Bumpers and over riders, How do i tell if they are replacement or not Austin Healey 5
J How can I tell if I have a negative ground tach? Austin Healey 5
J How can I tell Austin Healey 1
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
JPSmit Viva GT show and tell - and a question Other British Cars 4
M gotta tell somebody Spridgets 10
J How to tell if your car is from the South... Spridgets 15
rkep01 How to tell if lever shocks need rebuilding? Spridgets 3
I How can you tell if a transmission is good? Spridgets 2
S Oh the stories this car could tell! Jaguar 1
M Tell me I need a fuel tank sending unit Spridgets 21
jlaird Miss Agatha was trying to tell me something Spridgets 4
I How can you tell if a starter is good? Spridgets 6
T How tell if gear reduction start fits is right? Triumph 2
R Austin but can some tell me what model, please? Spotted 5
I Can someone tell me what these are? Spridgets 12
drooartz Manifold vs carb vacuum - how to tell? Spridgets 18
T Why don't you guys tell me this stuff ;-] Triumph 10
F Compression test: What does it tell me Spridgets 6
T How tell if wire wheels are good? Triumph 7
T Can you tell what kind of car this is Triumph 9
R How do you tell if a rim is bent or warped Spridgets 1
R Tell me this is not a big deal Spridgets 7
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
DrEntropy We're havin fun NOW I tell ya!! MG 26
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
JPSmit Show and Tell - new carpet & progress Spridgets 44
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
theleisure Silicone or Synthetic, How to Tell Spridgets 5
CCURTISS How to tell if paint is Enamel or Lacquer??? Restoration & Tools 7
I How can you really tell how old a tire is? Triumph 22
bthompson My turn for Show and Tell! Spridgets 12
kodanja Tell your worst TR horror story! Triumph 45
T Quick - tell me about your TR driving big miles Triumph 25
mrdibbles How to tell what year your Healey is? Austin Healey 14
58Custom How to tell diff btwn 1275 speedo & 1500 speedo? Spridgets 13
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
AngliaGT How to Tell if an OD Trans MG 2
tomshobby show-n-tell Triumph 8
N MGB How does on tell if an MGB has Overdrive MG 7
