mightymidget
My $500.00 Midget (68 negative ground) gas gauge is not working. you can ground the one side (wire) of gauge and the needle moves toward F.
Thought I had a bad ground so dropped the tank, The float was stuck. I unstuck. Now it moves freely. This is how I tested the sending unit to determine it is not servicable:
Removed the sending unit from the tank and sat in the front seat of the Midget with it in my lap. Then I hooked the ground wire from the gauge to the sending unit connection. then I grounded the body of the sending unit with a jumper wire to a known ground. gauge did not swing as I grounded or moved the float in the sending unit.
I need a new sending unit ..correct?
Order from one of the main suppliers?
