I have an '80 TR-7 Spider with the original twin Strombergs. Even though it's 30 degrees and windy outdoors, I went out to remove the carbs prior to a rebuilding session planned for this weekend. However, I ran into immediate problems figuring out how to remove them.
I have standard length 1/2 wrenches and set of stubby wrenches, so I was able to loosen the two nuts at the top of the carb-to-base studs, but I cannot see the bottom ones. I can feel one nut on both the left and right sides but neither wrench will actually work to turn the nut; either the angle of the open end is wrong or there's yet another bracket or hose in the way.
The online manual from BL just references "remove the carburetors" and makes mention - but no diagrams - of the nuts. Is there a magic bullet here? How many nuts are there and where are they located? And if you can find them, how do you remove them?
Thanks,
Jeff
Thanks,
Jeff
