Fuse amperage
Bill_Reid
I should be able to find it, but...haven't yet.
Can someone tell me the proper amperage for the two fuses which go in the Bugeye fuse block?
Thanks,
drooartz
Pretty sure they're both 35 amp Lucas fuses, someone will need to confirm -- you may already know this, but these look like the fuses you can buy at the local parts store, but are rated VERY differently.
https://www.drooartz.com/index.php?page=29
Jim_Gruber
Thanks Drew,
A good page to save to my technicaL specs / useful Spridget stuff File.A 150 page word file of trivia I've saved over the years.
Billm
As Drew's chart says- use 20 amp fuses (US rating) and you will be fine.
BillM
Jim_Gruber
Please see my note on using an inline fuse holder with a small rated fuse to test wiring harness rather than relying on those 20 Amp fuses to blow before the smoke comes out of the harness.
B
Bill_Reid
Thanks! Good advice on using an inline fuse holder with a small rated fuse.....will do it.
Jim_Gruber
Fuses are much cheaper than letting the smole out of the wiring harness.
Sarastro
For the second time this evening I'll suggest my write-up on the subject of fuses:
https://www.nonlintec.com/sprite/electrical/
There's really no absolute answer as to what value to use, as the electrical load in your car may be a lot different from what the electrical system was designed for. The suggested 20 amps is probably OK as long as you haven't added a lot of electrical stuff. If you have, you probably should add more fuses.
T 1971 Fuse Box and Wiring Triumph 7
W General Tech 2500S starter motor and fuse box questions Triumph 3
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
B MG Fuse Location Spridgets 2
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
T TR2/3/3A TR3 Fuse Question Triumph 14
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
M TR6 Fuse box wiring mystery Triumph 9
ckeithjordan TR2/3/3A Blowing a Fuse Triumph 30
charleyf TR2/3/3A Under dash fuse Triumph 7
M XK120 fuse problem? Jaguar 5
M TR6 Fuse, She Blows Triumph 13
S Wedge TR7 fuse panel Triumph 8
J TR6 fuse amps Triumph 2
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
RAC68 Battery Fuse Protection Austin Healey 101
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
D New Fuse Block Configuration Austin Healey 21
S License plate light - inline fuse, BJ8 Austin Healey 7
TR3driver TR2/3/3A Late TR3A fuse box mounting Triumph 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
K TR2/3/3A Wiring again: Fuse box Triumph 5
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
rjc157 Fuse box Austin Healey 9
Got_All_4 TR2/3/3A Need pics of fuse box area Triumph 6
jfarris TR2/3/3A Fuse to protect OD solenoid Triumph 9
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
K Popping my mind and a 50amp fuse Austin Healey 10
TRclassic3 TR2/3/3A Help with fuel gauge blowing fuse Triumph 6
Rut Fuse/relay box Spridgets 19
K Preventing fires, to "FUSE or Not to FUSE"? Austin Healey 24
B MGB 79B hazard line fuse MG 1
D TR6 Fuse equivalent Triumph 11
D TR6 Blower fuse Triumph 4
D TR6 Fuse Triumph 3
B 79 Midget,what size fuse do i need in each of the 4 slots? Spridgets 22
vette Fuse Sizes for New Fuse Box Austin Healey 11
rjc157 fuse box Austin Healey 12
S TR2/3/3A TR3A Blown Fuse Triumph 12
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
johnrip Wedge TR7 side marker Light issue fuse keeps blowing Triumph 2
B In-line fuse Spridgets 4
doates Fuse Box Problems Triumph 8
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
K TR4/4A TR4A Stock AM Transistor Radio Fuse Size? Triumph 14
wkilleffer 1993 Cutlass convertible blowing a fuse Other Cars 7
Brosky Easy add on fuse block Triumph 7
V Fuse amp ratings MK III Spridgets 1
