XK120 fuse problem?
matt-pz
I was wondering if anyone knows if the horn, headlights, turn signals, wipers, and fuel gauge are wired together under the same fuse... as they all stopped working around the same time. Any advice is appreciated!
Thanks!
maynard
I don't know the answer to your question, but if you get a wiring diagram, the answer will be there. In addition, it will save y ou many heartaches in the future.
LarryK
These older Jags have only two or four fuses. Since it is your steering column, yes to all on the same circuit. Make sure column is grounded. Just might have to dissemble and check wiring. Old wires get brittle and break inside insulation. Patience and no forcing of issue as it will be delicate. An old Autoball Manual has wiring diagrahms and some research through JCNA will be of use. Test light and voltmeter will be tools of choice. Most old Jags were junked because of wiring issues behind dash. Dash is capable of being tilted out and all connections will be revealed. Headlight switch can be culprit. Have found burnt wires in that area that can totally disable car.
LarryK
P.S. If you get a book with wiring diagram and memorize the wire colors, you will be able to know wiring for all older British cars.
AngliaGT Jaguar XK120 (?) on I581 Spotted 1
C XK120 Interior... and Interiors in General Jaguar 17
T XK120 fit 140 rack & pinion Jaguar 3
healeyblue XK120 coor latch question Jaguar 5
David Townsend XK120 OTS and DHC Limited Edition Prints Jaguar 0
Basil Jag XK120 Drop Head Spotted 2
H Jag XK120 ro=Zagato formerly owned by Scott Gauthier Jaguar 1
David Townsend XK120 FHC Fine Art Prints Jaguar 4
A Xk120 670501 Jaguar 0
LarryK 1953 Jaguar XK120 coupe Jaguar 5
Basil My old 54 XK120 Jaguar 4
J '52 XK120 FHD Coupe fender question. Jaguar 5
J Pics of '52 XK120 FHC project Jaguar 0
GBRandy Barret Jackson XK120 Jaguar 13
Marvin Gruber Any XK120 folks close to Alabama Jaguar 8
Tim_Creger Electrical upgrades for a '52 XK120 Jaguar 10
P Thinking about getting an XK120 Jaguar 16
F XK120 OTS steering box Jaguar 1
bcliff Who Wants a 53 XK120 FHC? Jaguar 5
G XK120 Brake hose needed Jaguar 2
bmurphy7369 XK120 FHC Project Car.... Anyone Feeling Brave? Jaguar 1
Sherlock early XK120 [with alloy body] on E-Bay Jaguar 1
J 1953 XK120 Vehicle Identification # Jaguar 4
D xk120 grill repair Jaguar 1
D xk120 wire wheels Jaguar 1
Basil XK120 pics from member Charles #677556 Jaguar 2
T 1971 Fuse Box and Wiring Triumph 7
W General Tech 2500S starter motor and fuse box questions Triumph 3
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
B MG Fuse Location Spridgets 2
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
T TR2/3/3A TR3 Fuse Question Triumph 14
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
M TR6 Fuse box wiring mystery Triumph 9
ckeithjordan TR2/3/3A Blowing a Fuse Triumph 30
charleyf TR2/3/3A Under dash fuse Triumph 7
M TR6 Fuse, She Blows Triumph 13
S Wedge TR7 fuse panel Triumph 8
J TR6 fuse amps Triumph 2
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
RAC68 Battery Fuse Protection Austin Healey 101
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
D New Fuse Block Configuration Austin Healey 21
S License plate light - inline fuse, BJ8 Austin Healey 7
TR3driver TR2/3/3A Late TR3A fuse box mounting Triumph 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
K TR2/3/3A Wiring again: Fuse box Triumph 5
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
