Front Brake Line Clips
jhorton3
Does anyone have part numbers for the clips that hold the front left brake line to the crossmember?
jlaird
They are called a hairpin clip.
Usually stolen of of cars going to the crusher.
Think I would ask Tony, he is always parting something out.
However, anyone might have a couple, you need two on that cross member.
fmichaels
you might be talking about vb part # 14-800. see page 108 (catalog sm.49)
jlaird
That's it. Cheep enough at 2 bucks each, think there are only 6 on the whole car. Two in front, four under the tunnel for the rear brake line and the fuel line.
Branson
i have some extras that came with my brake hose kit that Im willing to part with. they are black plastic. couple bucks to cover shipping?
jlaird
Hmm, should be metal. At least the orginals are.
Branson
these are a black nylon like material and are 2 pieces. theres a fitting that presses into the holes in the body or whatever and then theres a y shaped piece that locks into the fitting and holds the brake line.
bugimike
They should be metal if they are original parts! They are kind of a "V" clip that pushes into the mounting hole! I do not know how plastic ones would hold up in the long run, though I am not sure they are absolutely necessary so long as the line is routed out of harms way! They will certainly prevent "buzzes and rattles" of the line against anything else!! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
John Turney TR6 Brake Line to Front Calipers Triumph 4
R Help with BJ7 front brake line routing Austin Healey 6
T TR2/3/3A TR3 front brake line routing Triumph 3
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
jhorton3 Front Left Brake Line Spridgets 9
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
bighealeysource Front Brake Adjusters Austin Healey 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
I Bug eye front disc brake conversion. Spridgets 5
bighealeysource Question on 100M front brake cylinder Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
I Wanted Sprite front brake parts Spridgets Classified 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
T Assistance with Front Brake Lines Spridgets 3
doc50 Met front brake pistons Other British Cars 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
R TR2/3/3A Front Brake Conversion Triumph 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
G Rover P3 Brake Lining - Front Rover / Land Rover 2
K TR2/3/3A Front disc brake squeal.... Triumph 4
L Front Brake 100/6 Austin Healey 1
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
A TR6 '73 tr6 passenger front brake dragging Triumph 2
F Front brake hose BJ8 Austin Healey 4
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
F front brake hose 67 BJ8 Austin Healey 4
M Front steel brake lines Spridgets 9
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
R BJ7 Front Brake disc hitting Austin Healey 12
P Bugeye front drum brake picture Spridgets 7
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
bigjones Front brake job - any advice? Spridgets 94
RJS TR4/4A Replacing front brake hoses Triumph 10
C question on the front brake lines for BJ8 Austin Healey 2
nevets Front brake hose length Austin Healey 10
