bigjones
To yank out the starter motor, it was necessary to remove the distributor. Seemed like a good idea to remove it completely from the block - that way the timing is not lost (provided you remember where the rotor is pointing).
On re-install it did not look like there was a gasket there - either that or it decomposed in an oily mess. This looked like a good place for it to leak oil so I made a gasket up from proper gasket paper.
Anyhoo, I was looking through Haynes and there is a procedure for determining the thickness that this gasket should be to give an end-float of 3 to 7 thou.
Basically, you place a washer of known thickness on the shaft and re-install distributor. Measure the resulting gap between distributor flange and the block with some feeler gauges. You can then determine the necessary thickness of the gasket to give the end-float gap spec.
OK, fair enough - however, big problem. Knowing my luck, that washer can easily fall off the shaft, into one of the holes and into the inside of the engine. You can't stuff a bit of rag down there to block the holes because the shaft is high up inside the distributor body - ie. the rag would prevent the dist. from seating properly.
Any thoughts?
PS. I don't think this applies to the 1275 series just the 1500 engine (why not, I wonder?)
Any thoughts?
