New to the forum and need some put. A simple matter, but can't sort it out.
I have a 61 tr3a. First, the front/rear turn signals work. What doesn't work is the left directional light on the dash (red), also the ignition light. It does not flash as the right side directional signal does. If the bulb was bad it wouldn't light up. If the flasher was bad, nothing would work. There are only two wires under the dash which are secure.
Where should I look?
Tim
Tim
